ok back to topic...tools you will needjackjack stands17mm sockettorque wrenchratchetcrescent wrench
first here,s the item description
ok start lifting the car up and put it on the jack stands, you dont need to remove your tires or the engine under tray at all, just lift the cube enough just so you can fit under it
once you made it under the cube look at the tanabe illustration so yuo can find the installation point of the tanabe underbrace, once you find it start to remove the screws.
you need to break off the bolts since they are dead tight from factory you will need some "huevos" to break them off...lol!
once they start to move a bit put the socket on the ratchet, hold the top nut holding the bolt, use the crescent wrench and start to un screw the bolt at the same time when the bolts are almost out it will look like this
once the bolts are off start to install the under brace with the bolts, twist them just enough so they stay on place along with the under brace, put the socket under each bolt and hit it slightly with the ratchet in that way they will go all way thru and ready for re install the top nut.
hold the nut again with the crescent wrench and bolt it back, once its starts to get really tight, use the torque wrench and make i dead tight or as tight as when you remove the bolt and you are done
