Corey240's Big SR Project Q&A Thread
corey240
Car: 1993 Nissan 240SX Base Drift Machine
would it badly affect anything if i posrted out my stock intake manifold ? is it possible to be too thin and make a hole in it from heat?
corey240
ok so long story short im rebuilding my motor and saving myself about 3-400 bucks. so questions...this is for the bottom end, thats all thats getting rebuilt.
what are things i should do? im just doing an oem rebuild for now on my bottom end.
i am trying to source an fsm thats not on the computer, is there paperback copys of them out there?
what should i get done to the used crank and possibly block?
i have more just forgeting them
fregisr
Car: 240sx 1990
you really need the fsm to see if everything is still in specs. Get your block to a machine shop, get it honed out, have your crank resurfaced. I can't emphasize more but to get the fsm even the online copy, just print out the spec pages and the torque specs. I think I only printed out 20 pages in all when I rebuilt my whole motor including the heads. You need to the clearance of your bore with your pistons...etc.
driftin_sr20det
Car: 92 Coupe
You could gasket match. I wouldn't do any more than that without experience. Actually if you want to port something buy a cheap greddy-style manifold and clean all the casting crap out of those and have a nice manifold for cheap.
hpmachine
Car: '05 EVO8 + '95 240sx
yeah porting can be tricky. I believe even the surface texture of the metal in the runners can effect how it runs. (probably only in super high performance situations). try reading up on it first. probably wouldn't hurt to gasket match it though. you'd probably have to get the aluminum pretty darn thin before intake air temps/pressure could blow through it
corey240
the sr20de crankshaft will work on a redtop sr? if so does it need a different bearing size at all or anything?
SpeedRacer1
Car: 1990 240SX, G35
It will fit, same part. You only need new bearings if the bearing mark sizes are different between the crankshafts.
ILikeMy240sx
Car: SR Power
yup, what he said..
the mark on the crank will be different so you need to match the right size bearings for the crank.
I am running a SR20DE crank right now.
corey240
i found thes on ebay was wondering if anyone used them or somthing like themhttp://cgi.ebay.com/ebaymotors...QrdZ1
corey240
how do you re-assemble a piston to a rod?
corey240
im gona be less then 260 hp for a whil on my redtop sr, waiting to get bigger injectors and maf next. would an safc2 be good enough to tune a little for now? i only am looking for around 300 hp for my goal.
Dattebayo
No. SAFC sucks.
And of course, everyone wants "only 300HP"
corey240
my goal is 350 tuned down but 400 at track. but 300 will be fine for now. i dont have 1200 for a standalone right now.
youngmanvr4
Car: 94 3000GT VR-4/90 240sx
Look at your sig
Dattebayo
You dont need a standalone. You have at least 5 other options.
corey240
youngmanvr4 wrote:Look at your sig
corey240
anybody
nismofly
Car: 89 Nissan 240SX Hatch
safc will work to start, but ditch that ish asap
better would be starting with an emanage ultimate or even a pfc
corey240
i want a power fc with the commandr. like 700 shipped new on ebay but i dont have that cash and i can get used safc's for cheap froma couple people near me.
nismofly
do one for now to get it running and stuff, then just have that be the first step of phase 2
fast_s13
if you have to ask you prolly dont need to be messing with it
corey240
everybody starts somwhere. at some point and time you either asked our somhow found out how to do it so go e-thug in sombody elses thread
corey240
ok thanks. tuning is the biggest thing to do and i beleive it would benefit myself to have a power fc for any tuning job and all the other goodies to do it right but 1. i cant afford it now. 2. i cant afford it now.
fast_s13
im no post whore...ive been a member for four years and yet only have like 260 post...and im on nico everyday searching...putting a piston back on a rod is common mechanic skills
Logan76
Car: Junk
He never said you were a postwhore, but unless you have something construtive to add just dont bother.
corey240
does it need to be pressed in as in with a press that would be at a specialty shop? or just ring-pin-pound-pound-ring done?
ILikeMy240sx
Car: SR Power
First of all, First, second, oil ring scavenging rings (all three). They all have to go in certain orientation.
also, make sure you check your end gaps on ALL 1st and 2nd ring as well.
Once you orient them you compress them using a piston ring compressor (duh) and orient the piston/rod assembly into the bore and tap it with a hammer.
Make sure you put some rubber hose around the rod bolts becuase if you dont you will scratch either your bore or your crank journals.
Fahaka
Car: '96 S14 '07 Versa
Hey Corey,
Go to zeroyon.com and download the s15 fsm. It has all of the details regarding engine disassembly and reassembly. If you still can't get the wrist pins in/out take the parts to a machine shop, they have plenty of experience doing it.
corey240
i got the fsm. im just confused on if i need to take this to a shop and have it "pressed in" as in like wheel bearings. with a big *** mahchine or if i just do the "pressing myself" thanks ilike.
180fan
Car: 89 fastback
use assembly lube and you can push the pin in with your thumb once you've got one of the clips out. Remember to put back the clips on both ends of the pin when you've got it back in...
