Karateboy88 wrote:I'm liking the build.
Quick question about the paint. What kind of gun did you use?
And just FYI that's spot welding not stitch welding. Stitch welding is a continuous bead
I thought most of the seems within the 240 were spot welded in the factory or are the just glued? Most of them look like spot welds.
Also, what kind of welder did your friend use?
We used my buddies gun and im not sure what it is. He has a degree in bodywork.
It is stich welding. Unsure of the welder. My buddy has a few welder cause he does it for a living. Forgot what we used.
The body has a few, very few spots where it is welded. The majority is glued. They do that because I makes a smother ride, plus it is cheaper. By removed the glue and welding it I am makeing it stiffer. The daily ride will be ruffer, but my hadeling will go up from lack of chasis flex.
