jsherm007 »
https://forums.nicoclub.com/jsherm007-u86142.html
Tue Jan 22, 2008 9:25 am
At what mileage on the odometer did you finally get 'good' MPG?
I'm struggling with the new Rogue here, I have 760mi on the car and today driving into work I set the cruise on 72mph, and reset the MPG calc, and I'm getting readings of 14-17mpg for about 10mi. When I drove at 65mph, resetting the calc, I was showing 19-22mpg for about 10mi, and when I did the reset again and drove at 60mph for 10mi I was showing 21-23mpg. But I have yet to get 26mpg on the highway, except my first drive home from the dealer, even though I drive on I-90 42mi each way to work every day! I tried to but just couldn't drive it at 55mph today because of time and sanity!
I figure that I'm losing about $15/week since if I got 26mpg I'd go 408mi per 15.7 gal tank, and to go 408mi at the 20mpg I'm averaging it would take me about 20gal to go the same distance. The difference of 5gal * $3/gal = $15/wk; that comes to $750/yr at 50 work weeks per year.
I'm running 87 octane, 40psi tires, and as you've seen I'm trying different speed combos trying to find the 'sweet spot'. The weather here in MN has been cold, in the -10 to +10 degrees, but the roads have been clear so I don't believe the AWD is being utilized when I'm cruising on the highway.
