well my new 4.08 should me on its way heading east to Miami this very moment and installed on Friday at the dealer. If anyone is still interested in using my old rearend as a core to eliminate downtime let me know as I have not received any responses yet so I might be open to a lesser price.
Anyway...here are some figs that I thought you all might be interested in with using the different gears. The differences between the 90-93 car versus 94-96 car are due to 1st & 2nd gears in the transmission are different. Also this is a theoretical calculated speed that does not take into account tire expansion, wind resistance, etc. but it should give you a very close approximation for 1st & 2nd gear up to about 100mph what this mod does to the cars shift points at redline without JWT TCU (I don't know the JWT TCU redline figure, but I can edit this post easily if somebody gives it to me)
90-93 Stock Car .................................1st..........2nd..........3rd...........4thrpm redline...............6,900......6,900........6,900.......6,900 tire diameter (inches)..26.024..26.024.....26.024.....26.024 Diff Ratio......................3.538....3.538.......3.538.......3.538 transmission Gear.................2.784....1.544.......1.000.......0.694 constant....................336.135..336.135...336.135...336.135
theorectical calc mph...54.23... 97.79.......150.99.....217.56
90-93 With 4.083 Gear
.................................1st..........2nd..........3rd...........4thrpm redline...............6,900......6,900........6,900.......6,900 tire diameter (inches)..26.024..26.024.....26.024.....26.024 Diff Ratio......................4.083....4.083.......4.083.......4.083tranny Gear.................2.784....1.544.......1.000.......0.694 constant....................336.135..336.135...336.135...336.135
theorectical calc mph...47.00....84.74.......130.83.... 188.52
94-96 Stock Car
.................................1st..........2nd..........3rd...........4thrpm redline...............6,900......6,900........6,900.......6,900 tire diameter (inches)..26.024..26.024.....26.024.....26.024 Diff Ratio......................3.538....3.538.......3.538.......3.538 transmission Gear.................2.569....1.479.......1.000.......0.694 constant....................336.135..336.135...336.135...336.135
theorectical calc mph...58.77....102.09.....150.99.... 217.56
94-96 With 4.083 Gear
1st 2nd 3rd 4th.................................1st..........2nd..........3rd...........4thrpm redline...............6,900......6,900........6,900.......6,900 tire diameter (inches)..26.024..26.024.....26.024.....26.024 Diff Ratio......................4.083....4.083.......4.083.......4.083tranny Gear.................2.569....1.479.......1.000.......0.694 constant....................336.135..336.135...336.135...336.135
theorectical calc mph....50.93...88.46.......130.83.....188.52
I will probably see the biggest change, from 1st gear redline mph of 58.77 down to 47.00, as I will be also switching to the 90-93 transmission in another week, but at least for 1 week I will have just the 4.083 in there to try this out alone. This should really change my 0-60 times because I already shift at about 52-53mph (stock) so the one shift is already added in there. This might be different if I already had the JWT TCU with the higher shift point where I might just barely squeeze out 0-60 without shifting. Maybe somebody with a JWT TCU can comment about whether they need to shift before hitting 60mph. I would think that they would need to, but not certain.
for anyone interested in other variables as inputs....check out the link below for how to calculate any of the information as I did above.
http://www.4lo.com/calc/gearratio.htm
