Q45tech wrote:Gotta get your facts straight before you hit ENTER.
"The one on the nose of the diff should be for TCS."No!, ABS sensor.
I actually typed TCS or ABS, but then erased ABS. My mistake. It seemed strange to have an abs sensor in the pumpkin, a lot of cars have them on the axles, so as to determine which wheel exactly is locking up, or not.
Q45tech wrote:TCS and Active cars have two, one one each output and none on input of diff.
Gotcha, like above.
Q45tech wrote:transmission [vehicle] speed sensor:"had to be welded (?!)." Say what it bolts in and changes quickly and easily
It took me a couple of reads to understand your sentence. I now see what you meant to type was:
"Say what? The speedo gear bolts into the transmission and the correct gear changes quickly and easily!!!!!!!"
The following is the post where I read *something* about welding.
rsiwicki wrote:Speedo Gear Part # and procedure to get your speedo to work correctly.
Your local Nissan dealer can get you the speedo gear, but order inadvance as all the dealers here in Miami don't have it in stock.
The Nissan part # is 32743-35F20 and cost is about $17.95.
The speedo does not fit exactly and you have to do the following:
1. Rotate the new speedo in as it is wider than the OEM speedo2. It will look like that the gears will not fit, but they will after twisting in the speedo into the transmission to match the gears3. You will need relocate "tab" that holds the speedo gear in place with new spot weld to make it stay
Also it was suggested that we use a "LS Fluid with weight 85-140". He also said that the synthetic will free up the friction a little more. Is this the weight that you all use currently?
I now see he meant the tab that prevents the sensor from rotating, not welding the sensor itself.
Now I understand, so......thanks.....I think, and...uh....nevermind.
