Breadbox S13 Build thread
PapaSmurf2k3
Site Admin
Good luck man. Take pics and let us know how you make out.
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
Mmmmmm Virginia Country ribs, It was so good, falling of the bone.
I got the itis, but then got back in hammerdin mode and achieved a small victory.
I figured the trick is to fold the lip in a bit and then keep prying, my hand is numb from hammering.
*Today I got up early and took my flywheel to get resurfaced, +1 Cottmann Transmission Across the Street From Chimney Hill, Ocean Air Auto right next door.
Does anyone recommend using blue locktite on the flywheel bolts or is it not necessary after the 100ft/lbs or torque? It'll be fine with 100ft/lbs say the transmission guys.
Modified by breadbox at 8:00 PM 3/2/2009
PapaSmurf2k3
Site Admin
damn those ribs look good... and congratz on the hammering victory!
breadbox
89 Koop
84 720 4x4KC
My friend came over and we got my flywheel installed.
We got it on and all the bolts threaded before I realized the metal gasket wasn't on.
Now to install the clutch. Where do I get bolts to install it if I have none? What size are they? Can I get them at the auto parts store?
PapaSmurf2k3
Site Admin
You could probably use generic bolts... I can't remember exactly what size they are, but you also might be able to get a set of the bolts from a stealership. Just a thought. That is a good looking flywheel!
breadbox
89 Koop
84 720 4x4KC
Got the clutch on and torqued. Went to the dealer and got new rubber boots for the trans and ordered a new clutch slave cylinder. Hopefully will get trans mounted tuesday when I get my parts.
Trying to get it ready to goto the nissan meet April 18th in VB.
PapaSmurf2k3
Site Admin
Before you put that transmission back in, check out your clutch fork pivot ball bolt... mine snapped and I was going through slave cylinders like water... and you gotta drop the transmission to fix it.
breadbox
89 Koop
84 720 4x4KC
I will make sure I look at that, Thanx.
PapaSmurf2k3
Site Admin
If its broken or worn, SPLparts sells a stronger one.
driftneil
Car: A pile of cars.
FeintMind wrote:
I forgot to mention that I tried that as well... trust me, there are methods I tried that just popped into my head so i figured why not.
Including a theory involving a butane torch, and another theory involving dry ice...
If you don't own a dremel, I would VERY VERY highly recommend buying one... It is so worth it in the end... I've used mine countless times on many things... One time i had to switch out my ignition switch... and the screws that hold it on are blank headed screws... no way to unscrew them.
So I used the dremel with a metal-etching sort of drill bit and enscribed a slot on each screw. Voila!
Dremels are extremely versatile and small enough to fit in tight spots, while still packing plenty of rotary tool power to make your job 10x easier and 20x faster.
I endorse them fully.
The chisle and hammer idea, which, though it may eventually work, will make you more frustrated, possibly busted knuckles, maybe some pain to your fingernails, and tons more cursing.
Im not sure how much they cost but they are certainly under $100... an investment that pays for itself... when you consider time is money, you'll be saving both.
..plus you get to feel like a dentist. ahahahah
Got a trick, never got to use it. I was told if you have a grease gun, you can fill the pilot bearing hole with grease. Then take a 12mm(I belive) socket, and put the extention in the socket backwards. Put it in the hole, and smash it with a b.f.h. It should, in theary, push the bearing out from behind. Good luck, and if someone tries this, please let me know how it works.
gmac708
Car: :o)
1970 Datsun 240Z
1972 Datsun 510
Looking good, keep it going!
ThaiRacer
Car: 1995 240sx
really nice n i like the pignose like that can i see finish product please?
breadbox
89 Koop
84 720 4x4KC
I got a new slave and the rubber boots for the trans. pics soon.
I got a timing kit with an interesting adjustable gear.
Started on the nose again.
I am also going to try and redo a stock s13 seat to have better bolster and be more comfy. More updates as I learn to sew and cut foam.
breadbox
89 Koop
84 720 4x4KC
^^^^ that seat looks horrible.
Also got 2 teardrops back from my original 4 they are black now but its nice to have some 215's for the rears.
Modified by breadbox at 1:03 PM 3/19/2009
tramp_drift240
Car: 1992 240sx SE Coupe
keep progress goin'
im kinda liking how many people on here are in virginia. and ill have to keep Vadriven meets in mind if you guys attend that jaunt.
breadbox
89 Koop
84 720 4x4KC
I suck at owning a 240sx.
Well, now I am ready to put it together when I get my tools back later.
Also picked up another KA24e for $50 not to long ago, but it has a blown HG.
I have a z24 from my 720, so I am gonna compare heads soon.
I figure the trans won't go on because I ruined the pilot bearing putting it in, now I need a new one and then try again.
breadbox
89 Koop
84 720 4x4KC
Got one, just need three more.
15" x 6" '81.5 Datsun 280ZX Turbo
Nissan Part # 40300-P9000 Hollander # BS = 101mm or 3.98"
OS = +12mm 17 lbs $ 145 195/50-15 205/50-15 8-pointed snowflake Hard to find, heavier wheel
Need to use wheel spacers? Must use Nissan lug nuts!Photochop for what I am going for, I hope ReD*PiG doesn't mind I took his pic.
KAe vs Z24 head threadhttp://forums.nicoclub.com/zerothread/458470
My 720 threadhttp://forums.nicoclub.com/zerothread/402513
DIY Test pipe/ Gut your cat tutorialhttp://forums.nicoclub.com/zerothread/427942
I hope to be updating on mondays soon as I am trying to dedicate monday after solely to car stuff for me and my friends.
Modified by breadbox at 12:38 PM 11/3/2009
Modified by breadbox at 11:27 AM 11/4/2009
Coeur de lion
Car: 90 hatch with s14 KA-T (project)-'94 Pink Vert - '90 SOHC hatch.
I like it all so far!
breadbox
89 Koop
84 720 4x4KC
Woot! I love NICO. Found my coupe I have been searching for. Black Piggy.
Thanks to RaikkonensApprentice.
Time to goto work then bank.
breadbox
89 Koop
84 720 4x4KC
Just got my sweet coupe home. Pics up when there light tomorrow.
The exhaust is a bit large for the application, so this might be one of the first major changes. Noticed the exhaust has no resonator and is loud as hell. Hello BRM exhaust, sorry hatch but you can have the other, will be nice for your turbo I'm planning. So hopefully Monday I can get that on there.
Got a set of same size tires on there, gonna roll se's for a bit.Installed clutch fan and o2 sensor harness repaired.
Modified by breadbox at 2:05 PM 11/5/2009
breadbox
89 Koop
84 720 4x4KC
Pic from Previous owner.
PapaSmurf2k3
Site Admin
Looks pretty good man!
breadbox
89 Koop
84 720 4x4KC
Thanks James.
More pictures, after I got home from DMV.
breadbox
89 Koop
84 720 4x4KC
Looks like I'll need wiper nozzles and a tire.
Also there is no real low end power. Not sure if its the trans or just no back pressurre, hope its not a test pipe in there.
The trunk has a small leak. Need to insure, inspect and improve.
So fkn happy right now tho.
PapaSmurf2k3
Site Admin
yeah I was gonna say it looks like your drivers side rear tire is low
When does the 5 speed conversion get done?
breadbox
89 Koop
84 720 4x4KC
The autos are 5speed right? I have an overdrive button if the OD never gets engaged does that mean I am just topped out in 4th?
Idahos13
Car: 93 240sx hatchback
Auto transmissions are only 4 speeds.
breadbox
89 Koop
84 720 4x4KC
Well today I tried to throw the BRM exhaust on. Took off the old can laid it the yard. Grabbed the BRM 2.5 stainless. Mocked it up and it was a bit long for the hangers, so I take off the headers and set them next to my other ones I have and they are different by roughly 1".
Get new headers on, mount exhaust and then my steering rack hits my headers. So I shimmed the mounts up 1cm. Now there is a weird rattle/bad noise.
breadbox
89 Koop
84 720 4x4KC
Shimmed it lower and now it just barely clears, so I'll mess with it later on.
Did and oil change and runs great and sounds sexy with the BRM and no leaks.
There is some noise on slow down a bit above 1000rpm from the trans maybe. kind a weird rattle/grind
PapaSmurf2k3
Site Admin
Its a 240 man, its supposed to rattle. If it didn't... I'd be worried.
