Atl 240sx Owners, check in!
240CMO
Car: MONEY
if he don't want that finder I'll take it. Just noticed that the s13 I bought needs a front right fender.
JayPat83
whos car is that in that last pic above?
240CMO
Car: MONEY
Are you talking about the black one with the intercooler?
Camel
Car: That would be obvious....
Just for the guys coming to the meet. There is no alchohol allowed in the park. You want to bring a flask, that's your business, but don't get us kicked out by bringing a cooler full of beer.
Exar-Kun
Car: 2005 350Z
Camel wrote:Just for the guys coming to the meet. There is no alchohol allowed in the park. You want to bring a flask, that's your business, but don't get us kicked out by bringing a cooler full of beer.
shoot. there goes my contribution :p
I guess I'll brig diet coke, coke, and amybe some other drinks...
-chet
tm_kickz
Guys, I need some help.
My car wont start. I put in the turbo on saturday(Big 28) and I havent been able to get it started. I checked starter and wires, igniter wires, oxygen sensor, intake wires, coils, and put in a brand new battery. The damb thing still wont start.
The guy who put in my engine is trying to get out to me, but he's really busy with the drift event coming up on saturday.
Heres the deal I need someone who knows about wiring the sr20det. The car worked fine before I put the turbo in. I need it fixed today!
I hate to be so blunt but my girl comes in from Cali tomorrow and I would love to have my car be with me to pick her up from the airport.
I am willing to pay money to the person who fixes the car.
I live in Lawrenceville, Ga.- Close to AMC Colonial 18 Movie theaters.
I will give better instructions for the person coming.
Please call me, I will be @ work all day untill 9:30 so you will have to come while my family is here. Or wait till tonigh to fix it.
Please Help guys.
Its probably the smallest thing in the world.
Heres my info
Marcos(678)887-9130If I dont answer, leave a message. I will get back to you in 2min. I work in retail, so I will probably be with a customer.
Thanks GUys.
goldollar
Car: cars
Did Sam from tiger racing put in ur motor for you by any chance. does the car cranck at all, try checking your timing and look for any vacum leaks.
Supafly
just retrace your steps.... what did you mess with to do the turbo? go back over everything you touched and everything near something you touched.
navysnail
did you have to release fuel pressure, then forgot to replace the fuse or anything like that
xyster
Car: '00 Prelude
what does it do? does it just click when you turn the key, does it turn, but just not catch?
I once spent 2 hours trying to figure out why my car wouldn't start, checked every fuse, every relay, tried to jump it, basically went all over the electrical system....turns out the ground cable for the trunk-mounted battery had corroded. I changed the grounding point, greased it all up with that silicon dielectric grease, and it started right up. Just check all the simple stuff, especially stuff you assume is good. you never know what it could be.
Camel
i think he has a problem with the cam angle sensor. is there any sort of adjustment that anyone knows about for when you install it?
quote:ok check your fuel lines that go into the fuel rail you may have them reversed....and did you pull the cam angle sensor off???if you did i hope you just didnt slap the thing in there cause you need to put the motor on TDC and line up the marks on the CAS then install it but if you didnt do that you could be 180 degrees off timing
http://www.nissaninfiniticlub....ensor
another good thread:
tm_kickz
Ok.
Here goes.
*I checked the ECU just to make sure that any plugs were unplugged. Everything looks good.
*I checked power going to the fuel pump. A. O. K. there,
*I checked compression. I got 120 on all of them. Exactlly 120. I think thats the amount that I need.
*I also checked any loose wires all morning. I found that there is a red(thick) wire coming out next to the trans. I believe it is a negative wire. I hooked it up. Still no start.
*I also checked the Cam angle sensor. I was told by a friend(TheSnail) that the angle needs to be upright. I had it angled to the left. He told me to move it side to side real slowly while someone was turning the ignition. I tried that still doesnt start.
**I just checked the fuses. I found that the alternater fuse is busted. I will replace it in the morning.
Question: Would the car not start if the fuse for the alternater was busted.
*****I hope this is the problem. I would love to install my VLSD Tomorrow. Ill let you guys know whats up.*******
Special thanks to Camel for calling me. Also thanks to all you guys for answers.
JayPat83
not to go off topic but yeah that black hatch with the Unstable logo, who's car is that?
tm_kickz
OK. Guys just a small update. The CAS Is O.K. I ligned it up and evrything. We shal see if the car starts with the new fuse in the morning.
240CMO
Car: MONEY
It could be the fuse but I'm thinking that it's something else. Cause the car should be able to start with out the alternator working. I know the S13 I bought started with out an alternator on the car at all. But it drains the battery really fast. Did you make sure all your ground wires were on tight? How long has the car been sitting since it was last started up?
tm_kickz
About 3-4 weeks???
Drill_Sergeant
whats it doing? crank turning but not firing up? so there is power going to the fuel pump but is there pressure?
bootman
JayPat83 wrote:not to go off topic but yeah that black hatch with the Unstable logo, who's car is that?
is this the car if so my name is Quincy
240CMO
Car: MONEY
Could be the starter, have you had the starter checked?
Camel
I still need more donations for the meet guys. Hopefully some of you will ante up. 10 bucks gets you a reserved parking space and if we get enough, everyone will have food.
my paypal is at chaddhall@@@@@charter.net. just remove the extras.
89240sx
I'll donate as soon as my boss gets off his lazy arse and approves my vacation request. I'm also working on getting a co worker to cover for me and I'll switch with him another day... I'll let you know
JayPat83
yes that car quincy. did unstable do some work for you? how long ago?
bootman
I got the car from scott he use to work there
JayPat83
upgraded T3/T4? to go with that FMIC?
bootman
I still have a t25 running 12 lbs
bootman
I can still get the fmic from them if you want
JayPat83
i just thought you had some of my stolen parts. jason told me that when scott left he gave him my t3/t4 and my front mount that i never got back. it is just hard for me to trust people in ATL cause i got ripped off $4500 there.
bootman
sorry to hear that man I know that top hat still makes the fmic
JayPat83
not your fault i don't guess. yeah, i know tophat is still making this stuff. eventually when i get back into the turbo stuff Mike is going to do my whole setup. hope you people had fun today. wish i could have been there.
Camel
i am headed there for finals tomorrow with chet, should be a good time.
