Yup. The Versa uses a standard double-din mount, so any double-din nav system will fit. You can also use a single-din mount, but have to get a dash kit with a pocket to fill the hole.flyerno9 wrote:Are there currently any aftermarket in-dash DVD Navigation systems available for the Versa?
The head unit and all of the door speakers. I left the tweeters unplugged because I put in 3-way component speakers, so there's no need for them. This project was just an addition to the subwoofer I had already put in, I 'm just about to take pictures of what I can show you and type up the wire color chart.audtatious wrote:Good deal.
You simply replace the HU or did you hit the speakers as well?
i am assuming you used your stock wires to run the system?Jemdawg wrote:Here it is, hopefully the wires are the same in every car, if not you'll have to go the route I did with the voltmeter and the 14.4v battery. All of the audio wires are braided together, you probably have to cut the casing all of the wires are in to see this, and it would be necessary because some of the wires are the same color. Some of the speaker wires changed color by the speakers, so the first color labelled will be by the head unit and the other color is the wire by the speaker. If a second color is not noted, it is the same color and polarity throughout. All of the positive wires are the ones that are on the front side of the car, so if you're looking at the right door speaker, the positive wire is on your left and vice versa. This can help if these colors do not match up.
NISSAN VERSA AUDIO WIRE COLOR CHART
Brownish-orange(the thickest lead) - 12v ConstantOrange - IlluminationCyan - Switched Lead/Accesory wire/Ignition wireBlack - Ground
Grey - Right Rear NegativeTeal - Right Rear PositivePurple - Left Rear NegativeRed - Left Rear Positive
Brown/Pink - Left Front NegativeWhite - Left Front PositiveGreen - Right Front PositiveRed/Blue - Right Front Negative
I hope this is helpful to anyone at all, if you have any questions, feel free to ask me.
hmm i dont have access to my car, but i was looking at an alpine speakers, with a tweeder that had to use a cross over, can you take a pictures? i havent seen an SL interior in person because they are so rare to find out in socal. ThanksJemdawg wrote:As xekushnr said, this chart is applicaple only to the Versa SL, until somebody clarifies that it does in fact apply to the S trim.
I did not run new wires for anything, I simply spliced into the existing wires.
There is plenty of depth for the speakers in the door, and I used 6 1/2" Pioneers.
The tweeters are in the pillars that come up to the windshield and the dash, I'm not sure if there are grilles in the S trim, but there are in mine. If you can't tell where I'm refering to, I'll take a picture for you. Although, many component speakers come with a tweeter attached to it, like the ones that I got, it would be a good idea to get those instead, to make for an easier installation.
nice, but i ment if you can get picture of the tweeder cover/ door pillar? it would be nice, is there actual grills? because on the S model it just one solid peiceJemdawg wrote:These are the speakers that I have, no need for crossovers because the tweeter is attached.
no worries, i am in no rush, i was just curious.Jemdawg wrote:My camera broke, haha, let me see if I can find a picture somewhere.
thanks it those grill looking thing in the pilars. because the S model has nothing you can see, and if their enough space i would love to stick some 1 inch tweeter there if i get componetshubertq34 wrote:thanks jemdawg for the tip!
MIdnkight-lude, tweeters are located on the pilars.
Modified by hubertq34 at 10:32 PM 11/18/2006
I haven't even looked at it yet, but I'm guessing you just hook a line level converter to the rear two speaker leads?Jemdawg wrote:I added my sub before I swapped out the rest of the system. It's easy, if you're asking how it's done.
