Clipsed wrote:kolk, you have info to get the door panels off?
Its simple.
First use a small screw driver and pop off the silver ring around the back half of the door handle, Then pop off the black ring that goes all the way around the door handle.
2nd, take a small screw driver and pop up the plastic trim that holds the window buttons, and lock unlock button. This is all one piece, and mine were stubborn. Once they are off unclip the wire harness for the locks. With that out of the way you will see a brass screw holding the door panel to the metal door. Front doors have 2 srews, rear doors only have one.
3rd, with the screws removed, its time to pop off the door panel starting at the bottom. On my doors it seemed like one corner was always overlapping so it was easy to grab ahold of at that spot. Starting in one corner and working your way around the door, pull the panel towards you, you are pulling out push clips basically. Once about 8 clips are removed, the top part of the door that touches the window needs to go straight up.
If any white clips are still in the metal part of your door, pull them out and clip them back into the panel.
Assembly was basically the reverse, lower the panel straight down so the top is fully seated, then make sure you pull the wiring harness back through the door lock hole, then basically use the palm of your hand and hit the door in all locations to make sure all the pop clips are fully seated.
The only part that took me a second to realize, is the black trim around the door handle, one of the clips is not a forward style clip, it has to be lowered into place before the rest can just be push clipped back into place. Hard to explain, but look at the clips when you pull it off and you will see what im talking about.
Hope that helps.
