Jemdawg »
https://forums.nicoclub.com/jemdawg-u48609.html
Thu Nov 30, 2006 3:32 pm
You said this is for your '92 Sentra? Hopefully you have $20+ for a wiring harness and some butt connectors or female/male disconnects. Yours should be simple, and I'm sure you can find a guide for taking panels off somewhere. The wiring harness can be bought at Best Buy, and maybe the wiring components too, but if not, a local audio shop or Radioshack wil have them. The harness will plug right into the factory harness and all you have to do is match up all of the labelled wires on your new HU and the wiring harness, it should take no longer than 15 minutes to do this. I'll see if I can find you a guide, maybe it's similar to my 95 Sentra's installation, so I can help if you have questions, in that case.
