chixwithtrix »
https://forums.nicoclub.com/chixwithtrix-u97769.html
Mon Aug 11, 2008 5:54 pm
Engine/Performance-R33 series 2 RB25det with HKS head gasket, head studs-Greddy RB25 intake manifold-Garrett 3076r .82ar turbo-6Boost tubular manifold-Power FC stand alone ecu-z32 maf-Nismo fuel pressure regulator-Tomei 740cc injectors-McKinney custom engine mounts-Shaftmasters aluminum driveshaft-Nismo copper mix clutch/flywheel package-Welded differential-Griffin aluminum radiator-3" intercooler v-mount-HKS sequential BOV-dual e-fans-3" downpipe to straight pipe-ATV battery-Summit fuel pressure gauge
Suspension/Wheels-Tein front coilovers, JIC rear coilovers-Tien Camber Plates-Tein front Tension rods-Aftermarket Sway bars-SPL Subframe Spacers-SPL Rear upper control arms-diff brace-SPL adjustable toe links-SPL braided front/rear brake lines-Replaced Hicas subframe with regular subframe-ABS delete-5-lug hubs-5Zigen 17X10 +12 offset wheels-Cobra 17" wheels
Exterior-Seibon carbon fiber rear hatch w/ lexan window-custom vented stock hoof-30mm rear overfenders-M-Sports body kit
Interior-5 pt racing harness-SPL bucket racing seat-Removed rear seat/seatbelts/carpet and painted black-Dash switch panel for start switch and e-fans-Dash gauge cluster-HKS boost gauge-Greddy oil pressure gauge-stripped sound deadening
8/11/08About to start another round of mods so I thought I would post up the progress.
Currently '91 240sx w/ a stock KA. Bought it last year and immediately tore it down to make it drift ready, the first part of the thread will include those mods. It is a track-only car and has been to 5 drift events, about to start an engine swap in a few days.
New stuff on the table:First in line - RB25 swap w/ HKS 2835 Pro S turboIn the process of purchasing - complete 5 lug swap, body kit
Now on to the pics/build...
1st drift event right after we bought the car - cheap lugs were tightened too hard and stripped causing 3 studs to sheer off in in the rear. The rear drivers side brakes kept locking up and had to be bled and freed up a few times. The power steering had some kind of leak and it was like moving an elephant around the track (hicas equipped car). The stock seats were so bad I was lifting off the throttle to brace myself.
stock engine bay
New Koyo radiator installed
Yeah...125K miles KA
New gauge cluster
Pulled transmission for clutch swap
flywheel...yuck
New 6 puck clutch
Putting on Seibon carbon fiber hatch/lexan window woohoo!
Cleaning off the valve cover
Almost finished cover
On the car
Goodies - SPL brake lines for all 4, subframe bushings (later traded for subframe spacers, ran out of time)
Putting on the brake lines, ARP studs
New intake setup, pulled battery and relocated in hatch, less heat soak and shorter. Cheap 'n good!
Bad power steering pressure line.
Picked up a normal power steering line, had to modify the banjo part to fit, metal grinder is good.
VLSD out, welded diff in
Cleaned up engine bay!
Picked up a bucket racing seat w/ 5 pt harness. Now I'll stay in that damn seat! Also threw an S14 seat w/ 4 pt harness in the passenger.
^ that was the first month after we picked up the car. Hear are the latest mods within the last month.
Paint was fogging in the center of the hood and on the roof. Used a couple grits of rubbing compound to clear it up. This is not finished here, came out very smooth and black
Bought the car with KYB AGX suspension, took it to a few drift events and it was quite soft. Time to get rid of them
A buddy traded us his Koni threaded shocks w/ Eibach lowering springs and Tien camber plates. Nice to get it for free hehe. Much stiffer and more tunable.
After a drift event we picked up this CF hood for cheap, was in a wreck and was not fixed correctly. The front darker parts are covered with sticky, unhardened resin..yuck.
Ended up having to remove the resin with physical force, ground it off
The dull areas are the stripped parts, and the lumpy looking areas are...well lumps of unhardened resin. PITA to sand that down, still working on it, more pics to come from the hood
Thats it for now on the build pics, need to upload the latest pics and will post in a bit.
Current mod list
Non-engine Mods:-Aftermarket rear suspension arms-Koni threaded shocks-Eibach lowering springs-Adjustable front Tension rods-Aftermarket Sway bars-SPL Subframe Spacers-5Zigen 17" wheels-Unknown 17” wheels-SPL braided front/rear brake lines-Seibon carbon fiber rear hatch w/ lexan window-Carbon fiber vented hood (not mounted yet)-ARP wheel studs/Gorilla lug nuts-5 pt racing harnesses on driver and passenger side-Corbeau bucket racing seat-S14 passenger seat-Removed rear seat/seatbelts/carpet-Six puck racing clutch-New stock flywheel-Welded differential-working on swapping hicas rear subframe for an non-hicas subframe
Engine Mods-Custom intake-Koyo aluminum radiator-Electric fans-Custom painted valve cover-Short pipe exhaust-Relocated battery to hatch area-Greddy fitting for water temp gauge
Modified by chixwithtrix at 9:19 AM 6/26/2009
Modified by chixwithtrix at 11:38 PM 7/29/2009
