chixwithtrix »
https://forums.nicoclub.com/chixwithtrix-u97769.html
Tue Nov 11, 2008 5:35 pm
Now we're down to the more custom work of the build. Not going to make it to the next drift event this coming wekend, too busy, too broke and too many parts that need to be put on the car. Plus this stuff shouldn't be rushed.
First thing after the lifter bleeding was to paint the nasty valve covers. Here they are before being stripped:
One stripped, on primered
Black paint drying
On the engine:
Ian working on the custom bumper; taking stock S13 bumper and modifying it to duct more air into the intercooler. Cut from the bottom back and cut the front opening bigger. Then mounted the lower lip higher as you see it here:
Helped to use expansion foam to hold the part in place before/after fiberglassing
Getting closer, front glassed in and waiting to be sanded down and reinforced some more
Bondo on there to smooth it out
After bleeding the lifters and painting the covers I put everything back together and started it up. Ran great, supoer smooth and in-time. Unfortunately after about 2 seconds of running a strange tap started coming from the front of the engine. Narrowed it down to the water pump, and/or something under the timing belt covers...time to pull everything apart again.
So after everything was removed again I pulled the water pump. The shaft was slightly bent, most likely from the front end wreck the skyline this engine was in had. Hard to tell, but it had a bit of a wobble. Lokked pretty new inside
Also pulled the timing belt tensioner and idler, the idler was old so wanted to order another one in case it was one of the problems
Finally all of the parts I ordered came in. Since most of the dash gauges are bad or don't work I ordered a little Greddy oil presure gauge, STRI water temp and EGT, and a Summit fuel pressure gauge/adapter. Picked up a new idler, and a N1 ater pump for increased efficiency at higher RPM to replace the bent stock one. Lastly a few reducing couplers from the intercooler piping to the turbo elbow (blew the old coupler up) and intercooler piping to the odd throttle body size.
I've been working on cleaning up the engine bay's appearance. Cleaned off the grime from the intake mani, tucked the injector wiring, bundled up the main harness and started work on re-routing the under-manifold wires/hoses. Still need to wrap harness, clean more and paint a bit, but its coming along.
Lastly the install of the fuel pressure gauge. Had a T adapter to screw into, separated the lines and started the install. Planning to relocate the fuel filter a bit higher above the wiring harness to have good, clean visibility of the gauge.
