shannonferguson2000 »
https://forums.nicoclub.com/shannonferguson2000-u156061.html
Sat Nov 10, 2012 9:42 pm
SBC300, dude I'm so envious of your car,I need to rip off your dash design(carbon fiber and layout, its the tits
The 454 ate the cam and a rocker arm causing major bearing failure and scratched crank(I never checked the spring pressure on the heads, those springs were for a tank or garbage truck which is what gave me all the troubles with the cams), I had to have the cylinders bored to .60 over so now its a 468ci, new cam bearings installed, new pistons,rods, valvetrain, balancing, heads done, decked and cc'd, all the new parts put me around 2 grand, not including the bulletproof transmission build.
