shannonferguson2000 »
https://forums.nicoclub.com/shannonferguson2000-u156061.html
Tue Mar 30, 2010 5:30 pm
The rims are just to push around, dont worry, i hate mustangs also, here are pictures of the engine mounted in place, leveled, and mounts tacked. This is the basically the final engine placement and where it will sit. This is bolted to the mounts and resting all the weight on the front end. The suspension is barley squatting(i might need to add some more weight up front), just so everyone knows, this engine may be lighter than the vg30dett. It seems that way, and check out the clearance, this is with the widest pulley i could find, im going to use vette pulleys so that will give me another 3 inches or so, these pics are with the transmission mounted. [IMG][/IMG][IMG][/IMG][IMG][/IMG][IMG][/IMG][IMG][/IMG][IMG][/IMG][IMG][/IMG][IMG][/IMG][IMG][/IMG][IMG][/IMG][IMG][/IMG]Getting the engine level was not fun, have an open mind about motor mount, also have an open mind about chopping your $300 oil pan to peices just to clear the steering rack, 7 1/2 quart becomes 7 ish quart with the blink of a metabo. If your not a master fabricator or in my case 2 union boilermakers and a pro fabber who knows more than most, it will be tough. I also had to order a Mallory Unilight distributor(its 3 inches shorter than standard for clearance). These pictures do not show all the "moth@#%ucker cut it back out, or the 4a.m. "i dont know?????" Tomorrow I will fabricate a pretty transmission mount and measure for the driveshaft, and dont forget finish the tunnel fab so it will be sexy sexy!
