454 powered 300zx
shannonferguson2000
Car: 1990 300zx na, 1993 300zx na
New oil pump installed. Driving to and from work with very promising results. Video to be edited and posted tomorrow.
DCaff300ZX
Car: .
1993 CRP TT- Modified
Dude...you gotta make a shaker setup for that thing, it could look pretty cool... :gotme
shannonferguson2000
Dcaff, I wanted to do a shaker set-up but I think most cars that use that system have engines that sit much lower in the chasis. The top of my carb is even with the hood. Im sure with time and effort I could design and fab the shaker, making it look right is another huge undertaking. Fit, flow, form, and not taking anything away from th natural lines of the Z. Im leaning towards fabricating a cowl scoop but I dont like the way they look when installed. So I cant decide and Im already over my paint sceme also. work work work
DCaff300ZX
Car: .
I hear ya man, the lower plate would have to actually drop down I'd assume to give room for the scoop to have volume for air flow, but be low profile enough to not stick up too high above the hood.
I've played this through my mind from considering the VK56 swap potential, as it would also stick up similarly high I assume and would require some kind of intricate work to make it look right. Keep playing with it man, I like watching you go!
shannonferguson2000
With the popularity of high rise swaps one would assume a cowl inducion hood would be out there for sale. But for now I guess you have to build one.
SBC300
shannonferguson2000
sbc, what scoop did you use?
SBC300
shannonferguson2000 wrote:sbc, what scoop did you use?
G body steel from jegs.
I have pics of the whole process at: http://myweb.cableone.net/jburrow/300zx ... index.html
shannonferguson2000
Here's a little video I shot. Audio kind of sucks but you get the idea.
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
Niiiiiice! Oh too cool dude. Glad to see her out and running!
shannonferguson2000
Thanks Ace, Ill have a better video as soon as I can get a hand filming and a way to improve the audio.
shannonferguson2000
And the hood scoop endeavor has now begun. Im trying to find something that is not so 85 camaro but my hands are kind of tied. The rain never ends in Florida! Any ideas suggestions would be awesome.
BigTDogg (MA)
Car: 1990 Nissan 300ZX TT
Jegs looks to have a bunch. Maybe a smaller air filter or an oval shaped one would help you with the fit.
Nice conversion :dblthumb:
And to answer your question about the sound of the exhaust, it's because of your built-in microphone. You'll need an external mic to get the frequency response and sensitivity you want to capture an exhaust sound.
shannonferguson2000
thanks for the tip biggdog, ill have to find a mic, ive seen a few on jegs Im trying to find one with similiar hood curve.
NolimitZ32
http://www.racecomposites.com/stibolt.htm
Its a roof-scoop but maybe more of what you are looking for?
shannonferguson2000
New brakes, wheels/tires, and a few videos from the track pulling the front tires coming soon!!!
DCaff300ZX
Car: .
Yes, please!
:dblthumb:
shannonferguson2000
Hood scoop fab, finally!
NolimitZ32
That is going to be a b**** to blend the body lines.
shannonferguson2000
No blending on this job. I had to rework a flat, outer flanged scoop for the curvature to be tight. I'm going to build an inner flange for a bolt down scoop, paint it(along with repainting the entire car), and bolt it on. Glassing it on, I guarantee cracks in less than two years. I've seen it many times when dissimilar materials with different expansion/contraction rates are molded together and heat is applied. She ain't the purdiest girl at the dance but she puts out every time!
stm37s
Car: '12 Chrysler 300 SRT8
'11 Infiniti M37 S
'06 Range Rover HSE (Wife's)
'12 Chevy Camaro LS (Wife's)
'95 Chevy Impala SS (sold)
'04 Chevy Impala SS (sold)
'12 Hyundai Veloster (Daughters)
Nice build thread my brother, this should be a sticky, keep up the good work and keep us posted
NolimitZ32
shannonferguson2000 wrote: She ain't the purdiest girl at the dance but she puts out every time!
:rotflmao
shannonferguson2000
A few more pics.Image
Image Image
shannonferguson2000
I guess I'm going full roller this time. It only took around $7000 in rebuilds to learn my lesson. Big blocks plus flat tappet cams = nightmares. Here we go again, if it fails this time I'm cutting the block in half with a torch.
z32loverboy
Car: 1990 300zx CRP N/A 5 Speed (wreaked, now a shell) SOLD
1993 Slicktop CRP N/A 5 Speed w/ '90 built N/A motor and interior
1958 Ford f-100 straight-body (Grandaddies truck, resto-project)
Well, that's one way to tell her who's boss. Well, seems like you got it handled, any explanation as to why you keep snappin cams?
shannonferguson2000
I wouldn't say I've ever snapped a cam, but I have wiped 3 cams total. When dealing with flat tappet camshafts, if at any point the lifter stops spinning in its bore, your f***. And there are about a million things that can wipe out a big block cam(bad break in, low oil pressure, burrs in the lifter bore, idling below 1000 rpms even once, and many more!). For every 1 professional engine builder that says it's never happened to them I'll show you 100 builders that have had it happened MULTIPLE times. I actually don't know what happened, this lifter was smoked and two others had stopped spinning and started the lobe wiping process, but it cost me all my bearings I'm sure. Yeah, another rebuild!
shannonferguson2000
Well I found a big block roller core. I'm fully rebuilding this engine with all new parts, stroking to a 496, and plan on having it back on the road by the 1st of the year.
DCaff300ZX
Car: .
shannonferguson2000 wrote:Image
OMMFG...more Chevy fun. My favorite Chevy moment was viewing a 427 a guy had been racing that had blown the whole DS front corner off the block when the usual low-end failure came and touched off a symphony of destruction.
Four letters come to mind...F O R D
SBC300
Someone mention carnage?
DCaff300ZX
Car: .
SBC300 wrote:Someone mention carnage?
Holy FAWK, now THAT'S a problem!
Anyone missing a crank, and some pistons? And a block??? :rotfl
