If you can see in the pics I ended up with less than 1/16th inches of clearance from water pump to the Spal fan shroud. I can probably gain another 1/4 inch or so from some more massaging of the headlight assemblies.
WOW, glad you followed your intuition!shannonferguson2000 wrote:A funny feeling led me to remove my transmission pan to find that if I would have buttoned everything up and drove the car my transmission would have made it about 4-5 miles. The shop that I had overhaul my transmission left me with a broken throttle valve spring and a stuck tv boost valve which would have put me in a super low pressure situation burning up all the new frictions. IF YOU DIDNT LAY YOUR HANDS ON IT NEVER ASSUME IT WILL BE DONE CORRECTLY. PEOPLE ARE LAZY AND THE DAYS OF A JOB DONE THE RIGHT WAY HAVE PASSED. SAGGING PANTS AND HALF A$S RUSH JOBS ARE THE NEW NORM IT SEEMS!
Ace2cool wrote:Nah, I knew what it was, but I've done plenty of redneck stuff as to not even begin to question it. My buddy was feeding his lukewarm water from a sink and just letting it dump on the ground.
