1st gen 350 into 3rd gen camaro build
Oatmealman
Car: 2011 ford f150 fx4 5.0 master race
White Comet wrote:im not denying a fi system is better, but i wouldnt say theyre bad. what do u expect to find on an engine from 73? a lot of these parts he got for free from my dad, including the whole engine. my dad has 2 chevelles so he's not gonna have fi stuff and my brother couldnt justify going fi and spending that money when its easier and cheaper to do it the original carb'd way and still reach his goals.
orly? what qualifies as a muscle car then?
You coulda gone lp injection.To me a muscle car is a late 60's early 70's car that has a big block and takes corners like a boat does.
White Comet
Car: fc, s13 and mazda6, Sierra
so my dad's 72 chevelle ss isnt a muscle car?
slow40
Car: S13
I have to agree on the pistons, seems to me like the engraving on them will create weak points over time. carbon build up? car is gonna haul though. nice build
White Comet
glad you like it, i'll update shortly but we're waiting on a rebuilt t56 to be delivered
codyace
Car: S14 w/redtop
Nice build
Carbs typically will alwas make better peak hp though, than a FI setup....
And this car will drive every bit as easy and nice as a fuel injection setup. It's not he's building wildly cammed beast here ya know?
And the Summitt engraving won't affect anything. On a high boost detonation prone turbo car, maybe (as in hot spots on the piston), but in a nice SBC it won't phase it.
BoostFab
Car: S13cp, S13fb, S14z
Quote »[/quote]you're killing me with that sharp turn; redo that with a bend. i will put that in my "Worst Fabrication" category
Oatmealman
codyace wrote:Nice build
WRONG,
Its all about restriction of air flow and the proper mixing of fuel. A properly tuned FI system and carb that flow the same amount of air will make about the same amount of power with the edge going to FI. Carbs have no power advantage, but their difficulty to tune and sensitivity to pressure and temperature are critical problems that have led to the obsolecence of carburators. A high pressure sprayer can also better atomize fuel than a carb, so FI is also better at mixing fuel and air than a carb is too.
A lot of what I read above is BS, for example that a carb will better atomize fuel or that it will have a greater temp drop. The joule-thompson effect is just a fancy way of saying that if you expand a gas by lowering its pressure you also lower its temperature. To do so in an induction system you need a restriction. A carb needs the restriction to meter fuel, but FI does not. That temp drop does nothing good for the motor since this low pressure air will adsorb more heat than air that experiences less of a pressure drop before it reaches the cylinder.
White Comet
BoostsFed wrote:you're killing me with that sharp turn; redo that with a bend. i will put that in my "Worst Fabrication" category
if your not going to read, dont comment
White Comet
not much to update at the moment, my brother bought a t56 and we're waiting for it to get in
KLYPH
Car: Brougham
lol @ the boost gauge
White Comet
^ its for vacuum
codyace
Car: S14 w/redtop
Oatmealman wrote:
WRONG,
Do more research on how it all actually works before you comment.
Carbs will always make better PEAK power, not overall.
BUt what do i know?
xekushnr
Car: '90 Nissan 240SX Hatch
White Comet wrote:not much to update at the moment, my brother bought a t56 and we're waiting for it to get in
My buddy REALLY wants to do a T56 swap into his '85 ASC McLaren but he just doesnt have the money now after dropping about ten large into the motor. By the way, I showed this thread to my friend with the Camaro and he approves.
White Comet
^ glad to hear. yeah my brother was going to hold off on the t56, but he decided just to do it now instead of waiting for the t5 to fail.
minor update- the new hood, bumper and fender are being painted. i'll snap a few pics to show the progress
codyace
Car: S14 w/redtop
White Comet wrote:now instead of waiting for the t5 to fail.
I've got a few up my neck of the woods if you need one :Dhehe.
I know it may be close, but whats the cost of a smaller TKO setup for the Camaro versus the T56?
White Comet
i appreciate it but my brothers t56 just came in today. i know he was looking at the tko, but i think at that point his t56 was already on the way
Oatmealman
BUt what do i know?
NO, Have you not seen the horsepower carb vs fi showoff? They ran itb's vs a tuned carb. The itb setup made something like 14hp more at the peak than the carb.Carbs are outdated technology and arguing that they make more horsepower is futile.
OriginalWheelman
Car: '15 Ford Focus Electric
Carb don't make more power. They make the same power differently. Just because you get a surge when the 4bbls are open does not mean ti making more power. You're simply getting hit with it harder.
Urabus GodofTraction
Car: 2002 Subaru WRX Wagon
2004 Suzuki SV650
1988 Toyota Land Cruiser
1994 Honda XR600R
OriginalWheelman wrote:Carb don't make more power. They make the same power differently. Just because you get a surge when the 4bbls are open does not mean ti making more power. You're simply getting hit with it harder.
At full throttle, carbs and EFI make almost the same power. The problem is when not at full throttle. Another strength of EFI is in it's instant tuning. Changing altitude? Who cares! Running a little rich? *click click* fixed.
These days, unless your racing class prohibits EFI, you'd be pretty daft to built a car and not switch to EFI.
White Comet
charlieo wrote:These days, unless your racing class prohibits EFI, you'd be pretty daft to built a car and not switch to EFI.
its not a race car, its a street car so it doesnt really matter. its not worth it to spend the money to convert it to fi. its a 73 motor so it was carb'ed.
Oatmealman
Ya but you could have run liquid propane injection.
White Comet
update-
the t56 is here, but before it came in paint and body work was started.the fender and 4 inch cowl hood have both been paintedheres the car as it sits nownext up to be painted is the new bumper and the stock lipout with the oldand in with the newlast i saw the bumper was being prepped and once he has some free time, he'll paint the bumper and lip. in case i forgot to mention, my brother is painting the stuff himself.
and heres the t56, just how it arrived
Solar_Runner
Looks like it's gonna be All Business!
White Comet
^ yeah there isnt a ton of money dumped into it, but its always good to do something right once. i'll try to get more of an update later today. my brother was saying he put the new fender on. theres obviously a slight difference between the old paint and the new pieces. after a month or so, the whole car will be buffed (its obvious the whole car was resprayed at one point, a little orange peel every where) the whole car might get painted eventually, but its not a priority right now.
2004 Suzuki SV650
1994 Honda XR600R
How much did that T56 run him?
White Comet
it was like $1kish. then $100 for the cross member and im not sure how much for the clutch master and slave cylinder
White Comet
alright- sorry for the long absense, but i finally am updating this. the last that had happened, my brother was told the clutch and flywheel he had woudl work with the t56, so he bolted everything up and gave it a try. we found out the hard way they t5 clutcha nd flywheel is not comaptible with a t56 (at least not this particular model) so he shelled out the dough for a clutchmasters flywheel and zoom clutch. after installing everything we found that the force of breaknig the clutch for killed the slave cylinder too. luckily pepboys had one in stock. $40 and 20 minutes later the new slave cylinder was insalled and ready to go. the battery is charging right now and he's shooting to fire it up tomorrow and take it on its maiden voyage. if all goes well, it'll head straight to an exhaust shop and then off for tuning. while the battery was charging, my brother wired up the reverse lock out, hooked up the tail lights and fiddled with a few other wiring things. i dont think i've already mentioned it, but he went with a b&m short shifter and is now looking for a nice knob. the shifter surround has to go back in but then its good to go while he works on his next project for the car.......a gauge cluster. the tach and speed no longer read accurately so my brother's maknig his own cluster by replacing the factory gauges with autometer sportcomp 2 tach, speedo, clock and fuel gauge. he's also using 2 green lights for turnsignals and 1 blue 1 for high beams. he's also decided to use a red light as a shift indicator sicne theres no redline set on the autometer tach.
the car is very clos to running and i'll update again shortly with how the car's first drive is. until then heres a crappy cell phone pic of the car after washing months of dust off of it
Bubba1
Car: 2003 Nissan 350z
2024 Honda HR-V
2008 Toyota Corolla S
2001 Toyota Avalon XLS
Mr1der wrote:
rofl...an SB 350 into anything on the planet isn't original.
I do love 3rd gens even if they are huge pieces of crap concerning build quality.
I want an LS swapped IROC-Z because the 350TPI sucked.
I'm not even got mention the 305
Very true , bul consdering the 350 is replacing a V6 that's still a big upgrade. Sounds like a fun project. I have a 350 crate motor in my GMC, with a 4 barrel Holly.The only recommendation I have is stay away from Flowmaster exhausts. They sound downright evil, but you get tired quickly from it..
Logan76
Car: Junk
Looks good, the only things I dont care for on the car are the stock wheels and the 4 inch cowl hood, other than that it gets my stamp of approval.
White Comet
its all good. i like the cowl hood, and the wheels arent staying. but wheels are less of a priority then getting the car running
