White Comet »
https://forums.nicoclub.com/white-comet-u42048.html
Thu Oct 30, 2008 2:07 pm
alright. i only snapped of 2 pics before the battery died but heres what the exhaust looks like from the back. the pipes coming out are 2.5 inches and have a 45 diagonal cut on the ends
heres a few pics from the other day of the gauge cluster project my brother is working on.stock cluster removeda traced template used to transpose onto plexiglass and then be cut out for the new clusterthe plexiglass cutout.
i dont have any more pics since im not over there all the time when he's working on it, but my brother was using a jig saw to cut the holes for the gauges and the blade was a little too aggressive and it cracked the plexiglass. he cut another piece out and used my dremel to cut the holes this time. he also mounted all the brackets and secure the surround bezel to it. it fits perfectly in the place of the old cluster and all the gauges are in and just needs wired up but my brother said no pics until its a finished
he also got a new autometer sending unit for the oil pressure gauge (old one wasnt working) and has the moroso air filter on. heres a quick shot of the completed engine with the filter on, very clean and classy
to date, the things that need fixed are:- ps pump (sounds like its dieing already and its still new, its all good, its under warranty)- fuel pump weeps just a tad, not enough to actually drip on the ground, so it isnt too bad.- the carb needs tweaked for the af ratio- pass side header is cracked and leaking at the collector (damn cheap sh1t)
all easy to fix and the gauges being wired and af ratio being set will be done on saturday. 4 10 gears are also in the near future along with the posi unit already waited to be installed. the stock gearing makes the 1st gear waaaay to tall. i'll get more pics an vids on saturday
