550 lb/in front, 450 rear...This won't be too streetable, I'm pretty much just driving it too and from events.fullmetal wrote:what type of spring rates are you running? are you planning on keeping it streetable or track only?
Yeah, it has been, except for today...it was really too cold and wet. I can't wait until I graduate and I can move somewhere warm.MRNA wrote:Looks fun...
Since you're in Buffalo, you should come out to some WNY region events.Nis-240sx-san wrote:Hey, I didnt realize you lived in rochester. I'm in buffalo, and we got a ton of snow too. I have a red hatch just like yours, and it looks exactly like that, the snow and all.
May try that, but I'm not too concerned about it since I'm only going to drive it once a week or so. I want it to behave as well as possible, but I'm not expecting it to run like my LS400, which you can't even tell is running.blinker_fluid wrote:I hacked up an old tire and put a small piece of it between the mount and the frame. It raised the engine 1/4 inch but it also toned down the vibration about 50%. Make sure your bolts are tight b/c my power steering idler fell off and almost lost the passenger side fender.
Will do...Ali 556 wrote:OP,
you can't go wrong with KONI/GC setup.... ...and if you have extra ~600$ get a Execcive intake mani....will shave ~8 LBS and delet all the EGR Crap...And will add ~15Whp on the Stock"ish" KADE...
GOOOOOOOOOOOOD Luck I'll Do The Same As You In The next monthes...also when you have the car on the track...give me any feed back on them koni's....
GL,
Ali
Nice idea, but I don't think that modification is legal in Street Prepared, or even Street Modified for that matter.Ali 556 wrote:
Also If You Have MAD money...Go With Silvia Front End...I've read somewhere that you will save ~20-30 LBS...
And if you are realy CRAZY.....cut the raditior(SP?) support and weld some piping instead...you will save EASY 80 LBS....
GL,
Ali
GL,
Ali
Hey, what's up...yeah this has been a really long winter, the first event can't come soon enough. Still gonna be running in STS this year?scole wrote:Hey man, the car looks great! What are you doing for front strut housings?
I cant wait to get out there and race, ive been dying to all winter.
I got them from nolimitmotorsport.com. Yeah, If I ever replace these, I may go for the 8610s or 8611s, and I'll make the appropriate measurements to get the perfect size. I'll probably take you up on using that welder...I'll let you know.scole wrote:Where'd you get the shocks from? Koni has a bunch of variants in terms of rod length, stroke and what not. You might be able to get different inserts to fit a bit better.
If you need to get those spring perches welded on, my brothers got a welder at his house; it would take no time at all.
And yeah, still STS.
Silvia front will be legal for SM class. Radiator cutting & rewelding will put you in a Prepared class (EP in this case).nissanman04 wrote:Nice idea, but I don't think that modification is legal in Street Prepared, or even Street Modified for that matter.
