I have been running the Yellows for a few years with the GC kit ( 550 frt and 500 rear) --I like them. nice handling, good response.hai1206vn wrote:i'm quite curious about those Koni yellows. I'll really wanna hear your impression once they're on
Not sure about the SPL endlinks, I think the Whiteline endlinks should be fine.nismofly wrote:are you allowed to run spl's endlinks on your whitelines?
also by seneca lake you mean the events at the army depot?
ive considered running there from time to time, maybe ill head out this summer
You're welcome to ride shotgun at one of the events if you want...I'll let you know if I see anything for sale around here.hai1206vn wrote:i'm quite curious about those Koni yellows. I'll really wanna hear your impression once they're on
hopefully i can get a 240 before the season, maybe an s14 this time
I'm looking at the 14" or 15" wheel/tire combo mainly for cost reasons at the moment. Plus, this is my first set of R-comps and I think tires much wider than 225 may be too big a jump from street tires. It would be nice to have those 15x10s laying around if I wanted to try something wider...How much would you let them go for?91rs13 wrote:
to the OP I would rethink the 14 inch rim idea. I have run 15 inch Rewinds ( 15x7 +0) with 225/50/15's and 225/45/15's and have no issue with acceleration ( it is a CA18det ) --with the KA you should have plenty of torque to turn the wheels) --14 inch options in R Compounds are tougher to come by.
I would seriously look at a 16 or 17 inch option --or at least a 15. The 16's and 17's are more $$ --but you have the room.
Also --if you want a set of 15x10 4 luggers and would like to run the 275-35-15 Hoosiers --I will sell a set of rims cheap. I cannot use them on the track and want one rim for both AX and TT ( non SCCA TT club requires tires inside OEM fenders--and only 2-3 hot laps at a time)
whiteline endlinks are urethane and prone to binding, the SPL endlinks are solid, so not only will they cure the binding, but theyll be far superior overall...just not sure if youre allowed the solid endlinksnissanman04 wrote:
Yeah, the events are at the army depot. It's a great site. The courses are long and fast (80-90 second range, which is about double a usual course length). Definitely check it out if you're free. There's usually at least 3 or 4 events there, although the regional schedule isn't up yet.
It's pretty close to Improved Touring, however I don't really plan on going that route with this car.Soravia wrote:If you take your car to real road racing (SCCA) what class would it fit into?Or will you need more mods?
I would lean towards no on the SPL links, since bushing type may not be changed, as well as the amount of metal in the bushing may not be increased.nismofly wrote:
and ill definately try to make it out this summer, i think im going to try to stick with STX-ish level stuff while my car is still street driven
The 275's are a jump. Rims are steel Circle track rims--I guess $50 ea --I have 5. BUT the tires are not cheap the A6 in that size is $237 retail. (There are 4 worn out ones on the rims now)nissanman04 wrote:
You can run a full cage or roll bar in any SCCA Solo class. Most people do not because it is added weight and especially in the Stock classes or STS/STX the cars are street driven for the most part.nismofly wrote:nobody runs cars with full interior and no cage in real road racing
its why i find scca's auto-x class structure antiquated, because a fully stripped interior puts you in a class where cars are allowed to be tube chassis (afaik), but yet youre in a lower class if youve got built 500 rwhp motor but retain interior
yeah thats sort of what i was getting at, is that while you can keep it, its not required in anything besides showroom stock so theres no point to keeping it...and keeping it does compromise the cage design to an extent91rs13 wrote:
If you look at a Showroom stock club race car they must retain the stock interior but still have a cage.
You do not have to gut a car to install a cage, but most people remove interior to lighten the car rather than cage installation. Solo rules in certain classses prohibit that to keep the playing field level.
Even my SM car has to retain certain trim ( I disagree with those rules by the way) --but if I wanted to remove the trim --then I could move to Prepared.
Nasa rules are much easier to follow though. I like the points system for modifications.
Yeah I have seen those arms. It's cool that the bushings are stock-type, but I'm not sure if adjustable-length arms are allowed even if the bushings are the correct type. Anyone know for sure?mirochuki13 wrote:Hey. I'm looking forward to seeing your car come together. I'm building my S13 to run in STS next year.
By the way, you can get adjustable RUCAs with stock-type bushings from SPC Performance:
http://www.spcperformance.com/...cmd3=
Cool, how did the car do when you were in DSP?240marcuSX wrote:Hey, nice build you have going on so far.
I ran my 240 in DSP for about 2 years before I parted it out.
I still have the DSP legal oem TC rods with PDM bushings pressed in, and very slightly used Hawkl HP+ pads, if you're interested. I've been trying to get rid of them for months.
Let me know if you're interested.
I know they're legal in STS, not sure what the DSP rules say about this.nissanman04 wrote:
I might just take you up on those Hawk pads... What rotors did you use?240marcuSX wrote: I still have the DSP legal oem TC rods with PDM bushings pressed in, and very slightly used Hawk HP+ pads, if you're interested. I've been trying to get rid of them for months. Let me know if you're interested.
ya thanks man. When you start building, lemme know if you might need helpnissanman04 wrote:You're welcome to ride shotgun at one of the events if you want...I'll let you know if I see anything for sale around here.
nissanman04 wrote:I wish I lived somewhere that doesn't have winter.
