georgegto wrote:Did u use only a heat gun?
All you need is a heat gun, back of a screw driver, and a box cutter. When it comes to the inside of the doors you really NEED a heat gun (hair dyer should work) because the stuff did not want to stick on its own, but did very well once heated.
Ok so I started with the inside of the doors...
Heat guned it to promote adhesion...
Then I started on the ouside of the door, covering as many holes as possible....
Finnished left door..
Finished right door..This made a HUGE difference in road noise and even more so in the sound of my stereo.
Then I moved to the back seat. There is a huge hole back there on each side that causes so much road noise...First I layed the sound deadening....
Then I stuffed the hole with pillow stuffing...Which is $4.98 at walmart....
This made an AMAZING difference. The car sounds so solid when I close the doors now. When all was said and done my fiancee called me as I was saying goodbye to my friend Jarrett who helped me through all of this, My phone was inside the car and we were outside, her ring tone is The Devil Wears Prada- Still Fly and I could not hear it at all as we stood next to the car. Success tastes sweet.... o so sweet.
