FIRST COMPLETE DETAILING OF THE NEW (to me) 2009 M35:
Fetucini and I drove the car to Scooter's so we could do this without the wind blowing beach sand onto the surface while we worked.(an unavoidable terror when you live on A1A and your garage is full). Elasped time including waiting for final wax coats to cure: about 5 hours. Scooter, Ms Scoots, Fetucini, and I started after 4pm when the sun was almost down and finished in the dark, LOL.
1) Jet sprayed to remove dirt / sand that could scratch the finish during a hand wash.
2) Foamed with suds sprayer, allowed it to slide off, carrying dirt with it, then rinsed.
3) Hand washed gently with microfiber mits getting in the little tight spaces - rinsed.
4) Dried gently with Griot's MF drying towels.
5) Griot's Clay Bar and Speed Shine. (removes sediment, road grime, acid rain, and prepares clear coat for polishing)
6) Painter's tape over chrome trim and pin-stripes. (protects from buffer action). Hand waxed over these by hand later.
7) Polished with Griot's 6" and 3" random orbitals using Griot's Machine Polish #3 - removes any oxidation and faded spots in the clear coat. Removed with MF towels.
8) Wiped car with Griot's Pre-Wax Cleaner (removes any remaining polish residue).
9) Applied Grito's Paint Glaze with random orbitals (4-6 passes per area and removed with MF towels.. (fills in any remaining fine scratches, deepens clear coat, and evens out the surface for waxing)
10) Applied 3 light coats Griot's Best Of Show(Brazilian Carnuba) with Griot's random orbitals. I blended each area with 6 passes and allowed each coat to cure for an hour, applied a second coat
without removing 1st coat, applied third coat
without removing coats 1 & 2. Then let all three coats cure for 2 hours and removed with MF cloths.
(They use Griot's at the local Bentley dealer but do it in a HEPA room with 4 coats on top of each other, cure it overnight, add a 5th coat the next day without removing the previous 4 coats, curing for an additional 4 hours, then hand buffng).
These pics were taken the following day after we did the wheels, wheel wells, tires, and exhaust tips.
The pics do not do justice, but they do show the depth and clarity of the factory pearl finish.
Front DRLs installed
exhaust tips
tires, wheels, side view
This treatment will last about 5-6 months in the FL sun and heat. After that, it still looks brilliant, but less depth and clarity.
