tg wrote:nice job with the dice! look how clean it came out!
what are the plans for the nose?
In the end, the nose will look close to stock, I will be lightening the overall headlight assemblies and making separate mounts for each.
VigorousZX wrote:I was told that cutting the front end like you did would make for less rigidity in terms of handling and such but you probably have plans to compensate that.
Amazing project
As far a the two frame bar flexing relative from each other, I didn't lose much rigidity due to the upper rad support was thin. But I will have a much more rigid radiator support bar put in place to provide upper support. But as far as the strut tower vertical distortion, nothing is to be done. Because I am not using the strut tower. It's there for regulations purposes and provide some collision embracement.
ZXdriver wrote:This might sound dumb but what exactly does the dry ice do?
Not a dumb question if you are not from around the block. With out the dry ice, the sound deadening comes out in small chunks and leaves a residue behind. Dry ice condenses the sound deadening making it harder allowing come off in bigger chunks and it also pulls from the metal. You will notice it does help, 30 lbs is about ideal.
