Ghut300zx wrote:you painted in your dorm?
No, I was renting at that time, I did it in the unfinished basement, I hung up plastic sheets to keep the fine metal particles contained.
simmode1 wrote:Good stuff, Rare! I really gotta see how you pull off mounting up a VQ35 transmission to an RB26... Seriously, has anyone done that before?
Hmm.. no idea. I'd like to believe that it has been done.
tg wrote:
you can probably take the r32 bell housing and put it on the vq transmission... whether or not it will require an adapter plate I'm not sure... that or keep the vq bell housing and have the adapter plate between the block and that. Definitely going to need a custom drive shaft and mounts.
I'm guessing if f8 has considered a 260z manual steering rack and rb26 engine and r32 rear end... he's not a stranger to making things fit where they shouldn't
GL with the swap, looks like you're making very good progress so far but give us some details
Yeah, it's been interesting trying to decide what to do. You can't really swap the bell housing of the Z33 transmission. It's a permament fixture to the transmission case.. ie.. the bell housing is the transmission case.
I thought about cutting the bell hosing and bolting on the skyline housing. Problems are the shape of each and the input shaft length to be considered.
So far it's easier to make an adapter to fit. Problem is the you need the crank to be in the motor, I will be holding off assembly until the motor will be cranking within weeks. So, the work around is to build a wood chuck to fit inplace of the rear main and mimic the pilot bearing position. Now you can make a transferable(between transmission and engine) template. From there is deciding thickness for the adapter.
Once the adapter is made you now run into the problem that the input shaft no longer sits inside the pilot bearing. So a steel spacer will need to be made with a it's own pilot bearing. This is where it might come beneficial once I get pass the 6 bolt rb26 crank and 8 bolt 350z flywheel dilemma, I would be able to bolt on the 350z flywheel goodies, and use it's starter. And just to be a sneaky bastard, the 350z uses a crank angle sensor at the flywheel. And since I will be running a standalone ECU, it's more likely to fly.
Modified by Rare_f8 at 6:30 PM 3/14/2010
