rb26 efi harness with a chipped skyline ECU I'm guessing.labcoatmonkey wrote:Ah if only I had a fortune... what are you going to do for the electronic set up engine wise? stand-alone? What is the power range ur lookin at? This project is making me drool everytime and we havent seen nutn yet!
Soo your going to remove the CAS so you could put in a c.a.s?Rare_f8 wrote:^ I would also do away the CAS and put a crank angle sensor to get rid of the belt noise. I think tg knows a reasonable HP figure.
In Engrish prease?Rare_f8 wrote:I got in mind for a mix of hall effect encoder...that I can do up a trigger wheel about the crank.. I got a few ideas for that when I get around to getting sensors to work/characterized.
crank is stock.
In short.DCaff300ZX wrote:In Engrish prease?Rare_f8 wrote:I got in mind for a mix of hall effect encoder...that I can do up a trigger wheel about the crank.. I got a few ideas for that when I get around to getting sensors to work/characterized.
crank is stock.
Better for acceleration yes, top speed or touring, no. It isn't a major improvement over the NA diff. But if you had the TT diff you would notice the difference. But the 5 speed on the TT makes it need the lower ratio to allow it to be in boost longer to make it's power. I am not using the 5 speed, but a 6 speed so I have a little room to play around. But in the end, it's my tires that will determine how fast.GsaSlick wrote:I didn't realize the 180sx differential was better, I learned something today.
Rare_f8 wrote:Better for acceleration yes, top speed or touring, no. It isn't a major improvement over the NA diff. But if you had the TT diff you would notice the difference. But the 5 speed on the TT makes it need the lower ratio to allow it to be in boost longer to make it's power. I am not using the 5 speed, but a 6 speed so I have a little room to play around. But in the end, it's my tires that will determine how fast.GsaSlick wrote:I didn't realize the 180sx differential was better, I learned something today.
