speedeast »
https://forums.nicoclub.com/speedeast-u139789.html
Wed Jan 25, 2012 9:38 am
I got it and I'll give you a call sometime Anthony.
UPDATE:
The car is now in Florida! Actually, I can see it right now. Giggiddy!
This is the first drive in the car and it was a long one. Prior to this trip, I had only accumulated about 15 miles. There were some issues. Main battery fuse was blown and locating a replacement was a b**** and I still haven't. I was able to modify one that they sell at the local parts store to fit. The brake lights are staying on constantly which I didn't realize until about North Carolina where I got stranded with a dead battery for a short bit before getting a jump. The battery didn't even have enough juice to push start... Also, while in North Carolina, I changed out the transmission fluid for some Redline MT-90. That's some good stuff! I still haven't fixed the brakelight problem, but I've just been unplugging the brake pedal switch when I stop.
Total Length: 971 miles
Avg MPG: 22-24
Also, when I got to the car in Virginia, I discovered that someone had backed into the driver's rear quarter and the aluminum reinforced bondo used on the roof had cracked. So... don't use the aluminum reinforced bondo. The weather had also taken a little toll on other things, especially through the hole in the hood, but that's life.
Stay tuned.
