Update!
A lot has been accomplished since the last update, and a lot will be accomplished before the next. The goal to crank her up tomorrow still stands. Here goes...
We'll start with the fan controller. I acquired one from the local speed shop, AA Speed & Custom. They have a real nice outfit and the prices are decent; although, there in stock merchandise is geared toward American muscle cars. Anyway, I got the Flex-A-Lite fan controller, and it is temperature adjustable. It's the kind that you push through the fins at the radiator inlet.
Next up are the heater hoses. I never had the one heater line that reaches all the way to the thermostat housing, so when I finally got one, I had already installed a bunch of s*** around it. So, taking that into consideration and the fact that the bend at the firewall would be brutal, I went ahead and cut the pipe down to where it was a little under two inches long and installed it like that. That way the heater hose has a longer distance to distribute the 90 degree curve to the firewall and it works out much better. When it finally gets to the firewall, it still has to bend brutally to hook to the heater core. I went digging around at the parts store until I found an elbow that would help me out. The elbow worked great, the only problem is that the parts store only had one. So, I have to find another one today sometime so I can finish the heater lines. On the other heater line, I used one of those stainless coils that are supposed to keep it from bending. It seems to be working real good right now, though.
My friend, Santi, came by to help me out for a few hours. In that time, he installed my fuel hard lines for me and a few other things. We used the rubber insulated clasps to hold them in place. The lines are 3/8" aluminum feed and return. Then I cut up some 5/16" rubber fuel line and began installing and decorating with band clamps. I also created a custom fuel filter bracket because the oem I had was covered in yellow paint and bad memories, so I just said f*** it.
Next up, the electrical stuff that I got accomplished; although, there are still plenty of hours worth of it left to go. I took lots of notes: 1, I like to be organized so I can minimize mistakes; 2, I plan on doing a complete write-up on the elctrical changes required to VH --> S13 swap. I turned one of my pick tools into my new "connector removal tool." I can now pull all of the wires effortlessly out of the connectors for whatever reason I want I suppose. I removed the interior EFI connector from the KA... that was just a few seconds before I realized the VH connector is identical, oh well. I also pulled the 2 connectors off of the KA harness that connected to the "Engine Room Harness" with as much wire as I could manage. i plan to use these to create a bridge from the VH harness to the KA "Engine Room Harness." I finished sprucing up the injector harness. I also made note of the part number for the coil pack harness, just in case. I noticed that the letter/numbers were wearing away. I also installed the starter. The power wire from the starter will connect to the terminal shown in the last picture below.
There will be more!
