[QUOTE]Originally posted by MrFox "]The size of the rear tire traction circle has to increase (at the very least not get any smaller) in order for the rear tires to provide enough lateral force for her to recover.
Sweet.... again we agree!
Either u or N needs to increase for this to happen.
I'm with ya...
Getting better tires or finding a grippier road surface will increase u.
yep...
Transfering more weight on the back by accelerating will increase N.
Ummm.... see this is where the theory diverts from reality. Transferring more weight onto the rear tires MIGHT work in a straight line.... but only if the manner of transferring that weight ISN'T spinning the drivewheels faster!! This is a critical thing to understand. If the drive wheels are NOT gripping the road, than spinning them faster will NOT create enough weight transfer to overcome a traction loss that you are making worse by spinning them. The ONLY weight that will transfer is that created by the drive lines and weight of the tires and wheels (rear axle and driveshaft).
You can not accelerate because:accelerating will cause other problems...
and you can not maintain the present speed of rotation because that is quite literally causing the problem (back to the story of the rear wheels spinning faster than the fronts.. yes even if it's in a hydroplane). So the only way to counter the slide is to shift the weight onto the wheels that have control of the vehicle and slow the rears to the speed of the fronts.... again... pulling them into alignment.
Even if your theory made total sense (I'll give it about 85%
), it is counter indicative to what ACTUALLY happened. This would tend to show that UNDERSTANDING is no substitute for experience.
