Originally posted by MrFox "]Please forgive the tone of my previous post.
Sure thing... and I apologize for my overreaction. Long day at work + neck pain = bad mood!
But notice that letting off the gas (or braking) while turning will kick the tail out much more than spinning the wheels.
It has been my experience that braking or hitting the gas in this situation will have surprisingly similar results.... none of which are good. But, I can ONLY speak from experience. I have lived and driven in New England my entire life, in all manner of RWD and 4WD vehicles. Not to mention hill climb and off road racing.
Its a totally different form of oversteer than your burnout box example,
Agreed.
and cannot be recovered by letting off the gas because it was not caused by excessive wheelspin, but rather the lack of load on the back tires.
This I must disagree with. The only way a rear-end spin out can be caused at 50mph in a straight line (as far as I can tell) is by excessive wheel spin OR braking. Now, she didn't mention that she had hit the brakes so I can only assume that the rear tires were LOADED and spinning faster than the fronts... causing them to come out of line with the front. Therefore the solution would be to gently ease off the gas and allow them to slow to the pace of the front tires... pulling the rear back into alignment. Also, shifting some of the weight off the rear (the part that is losing control) and placing more on the tires that still control the vehicle. This is also not to negate the obvious importance of counter steering into the slide. This, as sky so eloquently mentioned, is vital. Steering input can make or break your recovery.
The other possible explanation would be TURNING, in which case bald tires would certainly be the culprit on wet pavement. Now.... if turning initiated the spinout, then the nearly perfect weight distribution of the 240 would tend to leave the outside wheels equally loaded and the bald rears would have created the slide. In this case it's hard to say what would have worked. I still believe that easing off the gas would tend to shift the weight forward and pull the rear into alignment.... but again... that's hard to say... I always have good tires on my vehicles. I'm sure you are a very experience driver.
Experienced.... I dunno... maybe. But, my Grandmother has been driving for over 60 years and even in her prime I wouldn't set foot in a car with her. Experience means little.
But experience is no subsitute for understanding.
Again.... we agree. I'm eager to hear your reply, I don't mind if I end up being the the one who ends up learning something from this.
Thanks.... umm I think. I've never studied on the issue... so obviously I can learn some things as well.
