l0nestar wrote:
Hmm.. I shall try this as well. Just let the car set like this for a while, and continue to attempt to 'burp' it? I can't find a hill or incline near by, and I can't use ramps. I'm on a stock S13, stock suspension, and 16" wheels, and the ramps still hit my bumper before they even touch my tires
ramps?
you own an rb power 240, get to the automotive store get a low profile jack, and a pair of stands lol.
That last time I bled it I turned the car on(cold), heater full blast, front end jacked, rad cap off, rad full (not over flowing left about .5 " room between the top of the endtanks) and overflow half filled. Once the thermo opened, burps and all kinds of bubbles were rushing out of the cap, spilling all over. (be careful to not let the car stall, all that fluid dumps on your alt belt and it will start squealing like a ***** trying to stall) I repeated this about 5-6 times of the thermo opening and closing before I saw no further bubbles/burbs leaving the system. Finished by capping that ****.
Notes
- be sure to refill the rad after it splashes some of the coolant out
-watch the coolant temps with the fans off, I switched mine on once they hit 200 ish degrees and continued the bleed while the temps feel off. ( I had to switch them off again at the end as the temps weren't allowing the thermo to open, use your brain on this one, its trial and error)
-once done fill your coolant over flow to its proper level.
enjoy!
