What was done to your 240 today?
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
zerepdivad wrote:stared at it while fixing my talon.
You're doing it wrong. :gapteeth:
I just hydroplaned in a left turn, but saved it before the curb. :squint: I need tires.
scotty-2-forty
Car: 1996 Nissan 240SX SE KA24DET
Hmmm, not much ... got into a magazine ... well, an advertisement ...
my-car-looks-so-freakin-hot-t503406.html
TheBlaiant
Car: Slow40sx
I wished mine was outside instead of my dads shop.
costa_rican13
Car: 1993 s13 coupe
did my own alignment after fixing the busted tie rod ends and a busted tie rod. :) yay me
wingFeather
Car: Current: 05 G35 Coupe
Previous: M35, M35 Sport, cube, J30, s13 sr20det, s13 rb20det, s14 zenki
Sprayed first layer of touch up paint :)
Nismo775
Car: 92 240sx Fastback 5 spd./2010 Chevy Camaro 1LT
installed my blitz nur spec r and BOY DOES IT SOUND GOOD! :naughty: . Installed clutch and i think i have a bad throw-out bearing. :facepalm: . other then that, thats it
slydewayz503
Car: 91 240sx-drft whore
97 240sx-daily beauty
Bought a Exedy Stage 2 clutch & flywheel from a friend for my KA in the mean time, hope to swap out the motor soon.
Seanzyyy
Car: 1990 240sx se coupe
started the teardown :mike
zeause
Realized i lost my cone filter and custom pool side material cold air box at the drift event yesterday. Also realized that i butt raped my rear hub bearings at the event. But after my first event, cant wait for the next!!!
nightsauce
Car: 1991 Nissan 240SX S13 hatch RIP
1992 Nissan 240S S13 hatch :D
few days ago i slammed a raised manhole cover bending everything in its path. Heres the list:
1. Sway bar (and the mounting brackets and bolts were bent)
2. Oil Pan and oil pickup (bent 3 oil pan bolts on the way)
3. Front subframe....yea the subframe
4. Motor mount broke and opened up
5. PS Lines were kinked
...just been avoiding the car til yesterday. I'm picking up all the pieces along with a 5spd swap this weekend. I'm gonna knock it all out next week.
Michaelmoore
Car: '91 Hatch
Opened up the box with more of the motor parts in it. 2 more checks and she will live again.
allenms240
Soaked the coils in PB plaster and took a pipe wrench to it, finally got them unsiezed!
Also replaced the starter that went out on me :/
slydewayz503
took my old gauge cluster apart along with all the interior related to that to swap our for my digital cluster
midnightouge
Car: 91 Fastback
Made a heat shield for my manifold.
It had melted a few things before so this should work.
jordans240
Car: Daily 2004 jetta tdi
91 240 hatchback-sold
R.I.P. 99 mk3 jetta
drove my second 240 home.
JoseBronx
installed front speakers
SoCal-S13
Car: 1984 Z31 50th Anniversary Edition VG30ET
kicked it for having too much potential.
rsmithdrift
Car: 1993 240sx fastback se.
finally got the replacement left rear brake pads and caliper to replace the ones damaged by the defective outer pad that came with my drill/slot rotor/ceramic pad kit today. It was not fun modifying the defective pad so it would work properly again after it ate my new rotor... f*** morons. atleast the customer service was good and they sent me all new shiz no questions asked. Brakes work so much better now that all the pads have the same depth.
Skyline_BNR34
Car: 2003 Nissan Sentra SE-R Spec-V
I changed the oil and oil filter, flushed the radiator and put new coolant in it, filled the tires up with correct amount of air, got it inspected, and got tagged to drive it on the road.
I bought it Wednesday.
I also started to sand off a thick layer of bondo the previous owner applied to the driver's side fender, and will eventually take off the fender and pound out the slight dents in the sheet metal of the Silvia front end.
breadbox
89 Koop
84 720 4x4KC
Tyler came over and we did his thermostat and waterpump, now his DOHC runs cool.
Also carried some of tile in my car. Funny to see it get another 3/4" drop instantly.
fijianrocket
Car: 95 nissan 240sx se, 74 jeep CJ5, 76 CJ5
pulled the transmission off without a hitch. I love the new compressor and pneumatic tools. going to be putting a new clutch kit in. Put in new ss lines yesterday. I cant believe how easy it is to get that thing off once you do it a few times.
TylerS13
Car: 1990 240sx
drove it with no plates cuz i just got it and need to register and re-insure it.lol
matt_240sx
Car: 1993 240sx Hatch
Drove it.
AZ89two4Tsx
Looked at old pictures of it, and really missed it. :(
TwoFourOhh
Car: 1991 240SX
Changed the fluid in my carbonetic 1.5way carbon LSD. This is the 600 mile or second time i changed it. ATS & Across says i wont need to change it again for another 2,000 miles. Thats nice. Buts simple anyways.
Peace
Dan
indomiekid1
Car: S14.
stared the s*** out of it!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
waiting for coilovers to arrive on weds.
i need paint.
damn it.
ciscos13
Car: 89' 240sx hatch, s13 sr
took front bumper, left fender, right fender and hood off. just ready to put the chuki front end on. waitin on the kouki tail lights to get here.
venom90s
Car: 91 240sx
70 ford maverick
i put some sea foam. installed a engine coolant sensor, 02 sensor and a fuel filter. now it run better than it did before.
MyKAkillsV8s
Car: 1993 240sx hatch
tried to figure out why the reverse lights come on in 4th gear just put everything back in and this crap happends think i have a sensor in wrong spot
duffman1278
Car: 89 240sx Hatch, the wildcats!
