What did u do to your Z today ???
TTkickedin
Car: 1991 Nissan 300zx TT 5 speed, t-tops, < currently in intensive care unit!
2011 MBTA BUS
it took you 45 MINUTES to pull a VG30dett+transmission from a z32?! You'd make a bad automotive tech at a dealer, unless you would charge outrageous prices for that one hour of work.
haha that's crazy man. My dad's been working on cars for 40 years and he could never do that.
UberBricky
Car: 1990 300ZX TT
Pulled out my power steering pump, reservoir and hicas solenoid. What a dirty mess, hard to tell if it was the feed hose or the hicas hose that was leaking, maybe both?
NolimitZ32
TTkickedin wrote:it took you 45 MINUTES to pull a VG30dett+transmission from a z32?! You'd make a bad automotive tech at a dealer, unless you would charge outrageous prices for that one hour of work.
Dealer Techs Charge book time, I got a buddy who's a dealer tech, he nets about 130 hrs per 40 hr work week. If you know how to get around something or just have the procedure deeply burned into your brain than its not too bad, and as I said this was the 3rd time I have done this to this car LOL.
Today's update:
Separated Engine and trans, pulled the DS manifold/turbo, Test fitted new mani/turbo/DP
sneek peak:
Muhib
Car: 04 Nissan Maxima SE 6MT Elite Package
90 Nissan Pearl Yellow 300ZX TT
I drove him after 7 long months. Drove to work this morning and already getting looks hahah
TTkickedin
2011 MBTA BUS
WOOT Just ordered one of theeeese.....
AND one of these! :D Stillen type III lip that is..
UberBricky
Car: 1990 300ZX TT
Ordered PS Pump rebuild kit, new hoses and hicas delete bar. Maaaaaaaaybe the roads will be clean enough to drive her in 3 weeks....
NolimitZ32
Ran leakdown test, :cry: Time for ARP studs and MLS gaskets. KIDS DON"T BUY JDM ENGINES!
300ZXttZMAN
Made a template and decided how I am going to mount my Blitz ebc ID 3 spec R boost controler, Tien EDFC, and HKS turbo timer.
Plus I can't wait to drive her again. It kinda brought a tear to my eye because the weather was perfect this weekend and still is.
Muhib
finally made a sig with Z!
TTkickedin
2011 MBTA BUS
:chuckle:
Now to fix your profile pic! Coupes aren't meant to be FF.
Only honda :nono:
buloushie
Car: 1991 300zx 5speed 2+2 NA
Cut driver's side fender lip and passenger side. Recovered passenger side seat as well.
ArticDragon192
Car: 91 Z32 2+2
Replaced the messed up front fender. Rolled and pulled them about 25mm. Pulled the rear fenders another 12mm. Test fit my TwinZ rear bumper.
Then sent the car off to paint :)
Muhib
almost beginning of April, so put up this calendar on my work desk :naughty:
Original pic
TTkickedin
2011 MBTA BUS
JaredM
Car: 1990 z32-300zx
ordered a ton of parts for 5spd swap, still cant find the clutch assembly/pedal anywhere ;(
ArticDragon192
Car: 91 Z32 2+2
Some updates from the body shop. Fenders are currently being smoothed out. And my old Veilside EC-I is installed and ready for paint. I've missed having a rear spoiler.
Front wheels specs are now 18x9.5 -3 with a 255/35 tire :)
Rears look so sunken being at a 18x9.5 +17 only, with a 265/35 hahaha
NolimitZ32
Pulled the heads
JaredM
Car: 1990 z32-300zx
thats what she said
TTkickedin
2011 MBTA BUS
Stashed this baby in the Mercedes, waiting till after work to go to the shop and start prepping for paint. Will also order 732 paint today :D
Btw some of the curves had some warping from Concept Z. Coz says that urethane gets softer in sunlight, so leaving it out in the sun would probably cure the issue. i know it's not summer here yet, so I'll be using a heat lamp setup to get rid of the small amount of warping.
Also, my order on the GTS roof spoiler 'solarwing' got postponed till this Friday, along with my turbos and the rest of the slicks.
ArticDragon192
Car: 91 Z32 2+2
Got the car painted and picked it up Friday.
This is the color, #RAY, Aurora Flare Blue Pearl, of the 2012 GTR.
Took it to the track not even 2 days later.
And blew the motor on the second lap of my first session, just moments after those pics were taken.
NolimitZ32
Build time!
300ZXttZMAN
NolimitZ32 wrote:Build time!
:yesnod
nick1809
Car: 1991 300zx 2+0 n/a slick top
ordered my plenum gasket! starting to pull the plenum. fml. i really didnt want to do this again.
TTkickedin
2011 MBTA BUS
My OEM rebuilt turbos, are on their way from south carolina :D
Should be just a few more weeks without the z. then a whole summer with it driving :P
Also got the rest of the slicks too!
300ZXttZMAN
TTkickedin wrote:My OEM rebuilt turbos, are on their way from south carolina :D
:mike :mike
JaredM
Car: 1990 z32-300zx
like the new color alot better than the old
Muhib
dropped off the red oem tt bumper today at the bodyshop. Dropping off the car on next monday and it shall be back on friday :ohno:
Basically, getting the front bumper repainted to pearl yellow and matching fenders, and the hood to the rest of the body. Will post before and after pics too.
TTkickedin
2011 MBTA BUS
schweet!!!
Z-owned
Car: 93 N/A Z32
90 VW Corrado
01 mr2 spyder
Deleted cruise control and some other misc. engine pieces not needed. Need to order plenum gasket, pcv's, valve cover gaskets etc. so I can get going on the plenum pull.
UberBricky
Car: 1990 300ZX TT
Installed the rebuilt PS pump, new alternator, rad, new downpipes..... Then just because I could, fired her up for the first time in weeks! Just hearing her is motivation! Now to install the rest of the exhaust, new rotors, pads, stainless lines and hicas delete bar and she's ready for the road!
