Yeah :/z32pilot62 wrote: I feel your pain, I've been battling Injectors(including P2) on my current Z for the better part of the time I've owned it. In three years I've put 10k miles on it and its supposed to be my daily driver... I've put 5k on my Honda since last October for comparison.
A larger pan wouldn't have saved me. The pick up was damaged.300ZXttZMAN wrote:Edgar holy s*** man thats horrible.
Might I suggest you get a SZ oil pan but see if Greg will make it for an NA??
Sounds like you are having some serious issues with motors, kind of sounds like a certain other person we all know, maybe not from this site but I'm willing to bet you know who I'm talking about.ArticDragon192 wrote:blew up motor #3
Poor Dax, he went through so many dang motors lol.z32pilot62 wrote:Sounds like you are having some serious issues with motors, kind of sounds like a certain other person we all know, maybe not from this site but I'm willing to bet you know who I'm talking about.ArticDragon192 wrote:blew up motor #3
Maybe its time to start that motor swap you've been talking about?
Don't have the money or time for teh 1JZ swap yet. Or the luxury of being down a car for so long. I'm just gonna go Frankenmotor in the Z now. I have a spare TT motor with blown HGs. Gonna pull the heads, get them decked and hot tanked, and mate them to the block of the original motor of my new Z. Should make for a nice upgradez32pilot62 wrote: Sounds like you are having some serious issues with motors, kind of sounds like a certain other person we all know, maybe not from this site but I'm willing to bet you know who I'm talking about.
That I do know. Hence why I'm doing it, hahaNolimitZ32 wrote:So....TT heads on a NA block? hmm, might be good for a few more ponies (better flow ya know)
Should be same compression ratio, maybe a bit higher due to decking the heads, but it's minimal. The difference is in the ports of the heads. More flow, more powerDCaff300ZX wrote:But, lower compression ratio?
Or is that in the piston dome design (CR)?
I know YOU know, I was just pointing it out for anyone that didn'tArticDragon192 wrote:That I do know. Hence why I'm doing it, hahaNolimitZ32 wrote:So....TT heads on a NA block? hmm, might be good for a few more ponies (better flow ya know)
Ed Zachary!ArticDragon192 wrote:Should be same compression ratio, maybe a bit higher due to decking the heads, but it's minimal. The difference is in the ports of the heads. More flow, more powerDCaff300ZX wrote:But, lower compression ratio?
Indeed I do. However, the whole head just seemed off to me as I was taking things apart. Some lost sockets in the valley, random washers chilling, a missing bolt holding the fuel rail down, stripped holes in the upper intake manifold (holes for the coil pack bolts), 2 dead injectors (I'm out of replacement injectors). With the TT head, I can reuse my fuel rail and injectors, since it uses old style as compared to the new style this motor comes with originally, and everything will be assembled by me, so I know exactly what's going on. Plus, more power from TT headsBigTDogg (MA) wrote:You know about the VTC caps, right?
The TT heads need to be milled anyways since they're coming off a motor with blown head gaskets, so it should raise the compression a hair. I don't plan on doing much to it though. Possibly some new valve seals and that's it. I figure a healthy VG with TT heads, Selin set up, shoter intake piping, headers, test pipes, exhaust, underdrive pulley, lightweight flywheel, tune, and a 4.3 final drive will be tons of fun. I'm shooting for 220 whp.Z-owned wrote:Should raise the compression of the n/a since you have it all apart lol. I will be curious to see what it dyno's with the tt heads on it.
ArticDragon192 wrote: I figure a healthy VG with TT heads, Selin set up, shoter intake piping, headers, test pipes, exhaust, underdrive pulley, lightweight flywheel, tune, and a 4.3 final drive will be tons of fun. I'm shooting for 220 whp.
You'll lose power with that set up, due to the intakes sucking hot air.JaredM wrote:ArticDragon192 wrote: I figure a healthy VG with TT heads, Selin set up, shoter intake piping, headers, test pipes, exhaust, underdrive pulley, lightweight flywheel, tune, and a 4.3 final drive will be tons of fun. I'm shooting for 220 whp.
buddy put down 210 i think on a similar setup. Is this what you mean by shorter intake piping? will be interesting to see either way
Nope, either a CA powered S13 or an R32 non-GTR.TTkickedin wrote:4.3 off a frontier?
I'd go with the leader gearset for a 4.1 f/d, have a bit more top speed. (On a TT though.) Specialtyz still stocks them.
I'm actually placing them right below the headlamps, right behind my foglamp ducts. Lots of fresh air, clears up the nose panel area for more cooling to my radiator, and gets more fresh air to the filters via the ductsBigTDogg (MA) wrote: You'll lose power with that set up, due to the intakes sucking hot air.
Placing them in the nose panel, planar would be ideal
