dontbugme »
https://forums.nicoclub.com/dontbugme-u28879.html
Sat Jul 01, 2006 2:45 pm
The chassis won't get hot,it has too much of a heat sink area but you're right the chassis grounds act just like the pos battery terminal except it's the negative polarity. All the current that leaves the pos terminal returns thru the chassis grounds. (Actually, the flow of current could be the other way, but that's a different story). The tests you need to do to determine the cause are simple, if you're careful and complete them explicitly. You need to determine if the ecu is getting voltage, if it is, then you have to check if the relay eccs is functioning to allow that current to return to ground and complete the circuit. See page ec-87 to check that. As for accesories that are working, you can see from the diagrams that many circuits don't pass through the ecu in order to work but the most important ones do. In a nutshell, you have to have power to the ecu then the ground ckt has to be complete for it to work. Get a good battery and hook it up via jumper cables to the original battery connection and connect the negative one to any piece of metal on your engine. GOOD connections for both! You said when you had the engine running it was shaking and running like a diesel, I think you either have a bad battery a connection issue or something came loose, shorts would have blown a fuse.
