Been trying to call u and it says you are un-available... If u need me to swing by tonite call me u have my #j-z wrote:welp its def not the dizzy. its been correct the entire time as i pulled it out and looked at the dots. put it in one tooth over and it wouldnt even crank. BUT one thing i did happen to notice is when id turn the ignition switch on to turn the fuel pump on id jump out and look at my fuel psi gauge. it goes up to like 8 psi and then drops back to zero in a sec or two. this is without the motor running (of course DUH). so this leads me to believe this is where my problem is. somewhere with the lower orings on the injectors. NOW this is why shell fire right up and then eventually die off in seconds, but its not bad enough to make it not run at all and thats why i can keep it running with my foot on the throttle letting more air in. damn, my fuking luck i swear. im done for today, so if its not raining tomorrow im gonna take those fukers out once again and see wtf is up.
If you look at your throttle body you'll see that the valve is closed at idle. This means the only vacuum in the system is after the throttle body. Air being sucked in to the IAC is not going through your MAF or throttle body due to your blow thru configuration. Pipe the IAC line in between your MAF and the throttle body for an easy test. As for your fuel pressure, when the key is on and the engine isn't running you should see around 25 psi and will slowly drop to zero after a few minutes with the key off, though on some FPR's this pressure could stay up for days. With the engine running at idle you should see around 34 psi w/20" of vacuum. This is what a '95 240 does, YMMV.j-z wrote:actually the iacv hose goes straight to the intake side of the turbo in the piping (all vacuum). the valve cover breather hose goes into the catch can and then into the intake side of the turbo piping (vacuum sucked). same with my timing cover, the hose goes into the catch can and then into the intake piping before the turbo (vacuum only). so each and every one of those being in the intake are being sucked through the maf. even though my maf is blow through, it all still goes through it. i still believe my problem lies with the fuel psi gauge going down to zero just after clicking the pump on. cause if it does it while the motor isnt running, then you bet it does it while it is running. also, ive got a question. should the fuel system still hold pressure after shutting it off? for those off you with a gauge on your return line what does it do?
When the IAC valve opens it sucks air into the intake manifold. Air flow with the IAC open is the opposite as you describe, if I'm reading you right, your idle air is going from the air filter to the compressor inlet pipe through the hose to the IAC. If you just disconnected it from where you have it now and leave it open to the atmosphere it would be doing the same thing as you have now and will not idle. The only vacuum at idle is in the intake manifold as the throttle is shut. Upstream of the throttle where the MAF is there is no or very little vacuum.j-z wrote:dontbugme, my iacv is still being sucked by vacuum. its routed to the intake tube on the turbo. at idle the air is sucked in through my intake pipe (where the iacv is routed to) and keeps going out of the turbo outlet through the inercooler, through the maf, and into the intake mani. it would be the exact same as if i had it inbetween my maf and TB except with my setup the iacv will only be seeing vacuum. i dont know if were on the same page or not, but ill take anything into consideration. you can explain yourself further if you want to. what about just removing the iacv hose and leave it atmosphere just to see what happens.
Looks like yours is set correctly at 9:30. Look at the third pic down, if your locking screw is approximately in the center of the slot your timing is correct as long as your rotor lines up with the cap and plug wire for No. 1 cylinder as shown in the rest of the pics.See: zerothread/161707j-z wrote:thanks for the input guys. as for the dizzy, ive looked at it three times now. took it all the way out and even installed it one tooth over. that made it not run at all. it made the rotor ending up at 11:00. how it sits now its at the 9:30 mark. where does yours sit now 300?? and where did it sit before you changed it? i honestly dont see how any car could run being a tooth off on the dizzy after removing it and seeing how far off it really makes everything. but you and 1995240sxse were running a tooth off?? please tell me where the rotor sits now.
