White Comet »
https://forums.nicoclub.com/white-comet-u42048.html
Sun Mar 01, 2009 6:59 pm
man there's been a lot going on since the last update, let's see the last thing i updated on was the steering bushing install. before putting everything in i thought it would be easiest to convert the car to manual with the steering column out of the way. i was just going to cut the brake pedal, but with the column gone i swapped in the manual brake pedal as well as the clutch pedal and gas pedal. there was no real reason to swap in the gas pedal other then the fact that i'm using the throttle cable from the other car and i just undid and replaced the whole pedal since i was worried i might snap the plastic ring that holds the cable to the pedal. with the column out everything was insanely easy. the whole 5 speed swap is stupid easy once you have all the parts. nissan outlines exactly where you have to cut for the clutch pedal and master cylinder. heres the clutch pedal just sitting in there waiting for the clutch master cylinderi pulled the old cmc just to test fit the holes and sure enough it fit like a glove.heres the old oneand heres how the holes should look from the bayi had to wait til the next day for the new master cylinder to come in and i also ordered a new slave cylinder at the same time. heres the new master cylinderthe slave cylinder i ordered was for a z31 and its looking good after some paintand here it is on the trans
the brake pedal bolted up
the gas pedal with new throttle cable
and heres everything installed without the column back in
and the master cylinder installedhere it is hooked up to the pedal
the new throttle cable (looking much better then the old one)
old throttle cable
next i just popped in the clutch line
in that pic, the clutch master cylinder is covered since i sanded and repainted the brake master cylinder
with everything run i was ready to put the column and steering bushing back in. it ended up taking insanely long, since i bolted the column in first after having the column entirely installed i really didn't want to take it back out to put the steering rod in first, so i tried to find other ways, the long and the short is that i wasted a lot of time and finally ended up dropping the steering rack to get everything together. heres a few pics from that hole progress
heres the column back in from the inside
before the engine went in i also touched up the paint and swapped the ps lines to the dohc ones
everything was ready for the engine to go in, but i got a little discouraged when i had to pull the trans again. somehow the slider got a little jammed and wouldn't allow the shifter to move at all. i had to unbolt the trans and remove the bell housing, but everything is fine now. heres some shots
earlier in the week my brother got a local alternator and battery shop to crimp on a 0 gauge ring terminal
heres just some random shots i havethe last pic kinda made me laugh, i cut my hand on something at like 2 am and i knew if i went down to the house for a band aid it'd wake my parents, so this was the quick fix.
i didn't have a camera for the last part of the update and my hands were too full anyways, but this quick cell pic should give you an idea the best part is thats with all the wiring already ran.
the engine went in nicely and i'll have more on that tomorrow, but heres a sneak peak at a side project that i'm working on
hope you enjoyed the update
