White Comet »
https://forums.nicoclub.com/white-comet-u42048.html
Thu Feb 12, 2009 7:45 pm
heres the update! i do want to point out that much of the current work has been wiring, BUT i felt that wiring info would be more helpful to other as a separate thread. so after i update in here, i'll be starting a new thread just for the wire tuck to be used by other for reference.
picking up where we left off, heres my remedy for turbo manifold studs. after much thought though, i'll be adding split washers on both sides just to be safe.
i put locktite on the threads that are threaded into the manifold as well as on the nuts.
heres everything mocked up
hmmm think this'll be a problem?
how its sitting now
heres the engine bay being repainted. hurray for my brother helping out
when keegan was over busting his *** doing wiring (thanks again ) my brother and i started stripping a bunch of stuff off of the engine. the engine was cleaned up a little more, and all the brackets and crap on it were prepped to be painted then sprayed black, while the engine and hardware is getting aluminum paint.
all the brackets being painted
i came over the next day and my brother had painted a bunch more for me, i took off the valve cover and sprayed it with another coat
i'm redoing the vc, since i was never happy with it the first time around. as you can see its just primered now. i ran out of time and had to go to work.
there wont be much to update the next few days since i'm working a lot but i'll link the wiring thread once i get it done
