gdz1la wrote:i think we are in the same boat, same engine chassis and box - the adaptorwhat chassis is that s14 s13?im doing a s15, (200sx in nz) silviaim using the vg30 startet (for steering rack clearance)have you done your mounts can i have a pic, im lowering the crossmeme 15-20mm iswell for bonnet clearance and weight balance.
for the shifter i was just going to put a rod from that first linkage, meaning 1st is now 2nd 3 now 4th and 5th now rev, but wouldnt take long to get used to would it? would be quicker and more practical.
There is one huge problem with the shifter setup you described. A friend of mine suggeste the same thing, but I had already thought about how it would work and it will be really hard to learn and a good way to blow your engine up.
Normally pulling straight back on a shifter is an upshift, pushing straight forward is a downshift.
Also, and upshift can be forward/right/forward, and downchange can be back/left/back
Well on a linkage with no pivot, 1st gear will be where 2nd gear normally is and 2nd gear will be straight forward, then to get to 3rd gear you will have to do what feels like a 1st-to-4th misshift.
Then straight forward to get 4th gear, which will feel kinda like downshifting.
Now lets say youre in 4th still and wanna go back to 3rd, but you forgot you have crazywackogearbox, so you pull back/left/back and you're now in 1st gear......... Unless your VH likes 12,000rpm it's BOOM......
Here's a pic of what I did on my car with the Z33 trans instead of a pivot cup in order to keep my shifter out of the back seat:
Modified by freethinker at 8:58 PM 2/5/2007
