Did you mean centimeter perchance ?elwesso wrote:.....(think 1-2-3mm)... I think itd be ebtter to make it thinner, rather than the thicker one that John was making...
From what I've heard (a friend has some car part molds) it is expensive to get them done. You need a negative, a postive and the final, something like that. Do you think you could get them done at a reasonable price? I didn't really like the flywheel spacer but currently it's the only option for us that have been waiting on John.Mettler wrote:
If I could get access to a VH45 motor & a Z32 gearbox, I could rig them up and then spend a bit of time performing measurements. Model a bellhousing in 3d with provision for mounting a clutch fork on either side and use my 3d model to have a mould CNC machined, then cast up bellhousings.
no its way thin.... I was thinking like a thickish washer.... certainly no thicker than the head on the factory infiniti Q45 keys....anlasak wrote: Did you mean centimeter perchance ?
Because 3 millimeters is WAY too thin.
???????????? ^^both RB bellhousings and missions and yes removable^^ ^^Z31 bell housing and mission..removable^^elwesso wrote:thing is, if you dont use a nissan box, then theres no chance of using factory mounts.... and theres no nissan box that uses a removable bellhousing (which sucks)
Ok. When your money has been tied up for months (5) on something that should have taken a week or two and you have no option but wait as long as it takes because you have a pretty good deposit that is not refundable. I think we have been pretty reasonable. He did not do this group buy for our benifit. The part was already done, just needed to make 10 more. The trouble he needed to go through to get them done was known by him as was the profit.Ezekial wrote:Give John D a break guys ... He has gone to the trouble of organising the big group buy ... in most cases, the time and stuffing around actually makes it NOT WORTHWHILE for the person organising it ...
Thats dismantling the whole box by splitting the main casing, ie oil everywhere.. Sure any gearbox can be pulled down, but what we are referring to is the *bellhousing*Here is a pic of a gearbox which is 'still together' but bellhousing removed. This cannot be done with most of the nissan manual trnasmissions.WidebodyZ wrote:So I'm a little confused as to what you mean by not removable. I've personally removed them myself. You can clearly see the bolts that connect the two sections quite easily.
Wait I am confused? Which transmission is this? It looks a lot like the VH45 bellhousing but the gearbox looks very much like the supra one above (except the shifter section bolted on near the output yoke looks slightly different).Mettler wrote:And here (mine):
The confusion is that you didn't read what I posted. WE HAVE SWAPPED MOTORS USING VG MISSIONS WITH RB BELLHOUSINGS. Should I make it bigger and more bold next time? Must have been in dreamland when doing these motorswaps... (also used VG missions on L series bellhousings on S30's) Don't let the door hit you on the way out smart guy. OH NOES!!! GEARS AND OILS!!ultrapulse wrote:When I said oil, I meant oil, bearings, synchro rings if U separate what u call the 'removeable bellhousing' , and u said you're a little confused?!, small wonder. Some people just cant seem to admit theyre wrong. No most nissan manual boxes dont have removeable bellhousings, yes I have mated up a t56 which does work.
