Update/240lookis' 1990 Hatch Project
The240seller
Car: 240sx
Cars and bikes are wheres its at. I ride a dmr rythm, but planning on getting a transition double. Keep up the good work, lovin the build.
240lookis
Car: 1990 240sx hatch
Just picked up a dohc p/s reservoir and air intake. Anyone running sohc p/s lines on dohc reservoir with a ka24de?
Also installed my circuit sports v2 shifter, and wow, gear engagement feels much better. very solid.
I also have a bunch of oil/coolant/other fluids ready to be put in.
ANyone want to give me some tips on hooking up the clutch cable? Pretty sure I didnt hook that up.
mRodiek
Car: Stock Hatch
How is the install of the shifter? I was considering picking one up..
Future_gohan
Car: 91 240sx, 91 vert
240lookis wrote:Just picked up a dohc p/s reservoir and air intake. Anyone running sohc p/s lines on dohc reservoir with a ka24de?
s13's use cables? i'm confused lol
Idahos13
Car: 93 240sx hatchback
Negative!! They have hydraulic clutch systems.
Future_gohan
Idahos13 wrote:Negative!! They have hydraulic clutch systems.
Lol I know.
240lookis
haha well obviously i dont know much. if i just tracked the clutch pedal past the firewall would i see the hydraulic hook up easily?
mRodiek wrote:How is the install of the shifter? I was considering picking one up..
pretty simple, however to unscrew the 5th and 6th screws that arent seen in that picture, you have to find the best tool setup with the limited space above the transmission. it just took some finesse and time.
Future_gohan
240lookis wrote:haha well obviously i dont know much. if i just tracked the clutch pedal past the firewall would i see the hydraulic hook up easily?
Go under the car, on the passenger side of the transmission, you should see a rubber hose hanging there, screw it into the slave bolted to the transmission then bleed it. your good to goo
240lookis
thanks dude!
Coeur de lion
Car: 90 hatch with s14 KA-T (project)-'94 Pink Vert - '90 SOHC hatch.
I am running sohc PS lines on my DOHC
240lookis
are you running dohc reservoir? if so, how did you reroute the lines to the other side of the bay? picture?
2zz
Car: '91 Nissan 300zx NA ZLICKTOP
mmm, progress.
mRodiek
Car: Stock Hatch
Give me your wheels, I already tried Teddy but he wouldnt budge.
240lookis
this car is very very slowly progressing.
if anyone wants to sell me their clutch line that would be much appreciated:
as far as everything else, it all looks the same.
actually, i dialed in my rear fitment a bit more.
Modified by 240lookis at 6:02 PM 2/21/2010
240lookis
i took out my p/s for the time being. just gonna wait until i have cash for dohc p/s lines.
i decided that i didnt want to leave the steering rack open and vulnerable to dirt and s*** so i got some plugs
i also finally picked up some brake line and hooked up my clutch slave
then i realized that i was missing the drain bolt on the slave cylinder when fluid started spurting everywhere. so i went on a mission for the bolt. nowhere in seattle has one. napa, carquest, autozone, fittings inc. nowhere. so for the time being, i am using a bolt that fits, and an o-ring, tightened all the way down so the hex is against the slave. opinions on how long this will last? if at all?sort of hard to see
then i took a picture of my wheel fitment for s***s
240sxJoe91
Car: 1991 240sx Ka24de
Post more pics of your rims please i like them, i would like them for my car...its grey ( obviously in my sig ) so please if you dont mind post more pics of your car(s) rims...full body shots please..thank you and your car is coming along very nicely
mrgreeneyes
Car: ///M5
Parted Out Built S13 Coupe
just buy a new slave. much easier. also, delete that clutch damper box. save yourself TONS of headache.
otherwise, carry on
240lookis
clutch damper box, as in this?
and i may just buy a new slave, but if i can find the bolt on a soon to come junkyard scavenge, then i will not.
240lookis
240sxjoe - i have several pictures of my car in this thread. several.
Coeur de lion
^^ lol
lookin' good still. And I never saw your question. Sorry. I just moved my reservoir to the appropriate side, drilled an additional hole for mounting and bent the lines the right way. One of these days I will just do it the right way. Works for now though.
mrgreeneyes
Car: ///M5
YEP :D
spooled240
Car: kouki s14
seems pretty straightforward, you just have to remove that unnecessary box and bend a line:
http://garage.projectraine.com....html
240lookis
ya thats pretty easy. ill do that this weekend. MGE - have you removed it? any significance difference in clutch feel?
Hooked on 240
Be a man and take that box out.
Car's looking good!
christs13
Car: 1991 nissan 240sx
love the car mang, that one LLEH of a outcome
RustspecS13
Car: '74 260z and '88 300zx turbo
240lookis wrote:ya thats pretty easy. ill do that this weekend. MGE - have you removed it? any significance difference in clutch feel?
It shortens the pedal travel and stiffens it a little. Nissan calls it a clutch dampener or something like that. Also it makes bleeding the clutch unnecessarily harder.
I just read most of the thread. Good work, I wish I had done more work to my last s13 when I was 17/18. I was always afraid of messing up, but I just decided to jump in and god it done, nice to see some one else with a similar attitude.
~Alex
240lookis
Hooked on 240 wrote:Be a man and take that box out.
done
decided to just get a new slave, and then the day it arrived i found the lost drain bolt
and then i found this crx c pillar bar that i had accidently bought. random metal bars are cool so i bolted it up in a place that looks cool.
and the car still doesnt run
troskinatior
Car: A Two Tone Piggy Coupe
You accidently bought it?
How hard was it to take out the clutch box thingy.
240lookis
well i thought i bought one for a 240sx but the s***ty ebay seller sent me a crx one. it was like 20 bucks so i didnt really care.
and the clutch dampener thing was super easy to remove.disconnect two lines, remove the dampener, bend a line, bleed clutch, done.
christs13
the clutch box is easy to take out, its 2 fittings and some line bending and your set.
