The Low Down: On Lowering Springs Y34
stroked347
Car: 2003 Infiniti M45
This was the only set from this particular source....
I bought mine from a guy who is selling his M45. He bought the springs two years ago, never installed them and was going to include them w/ the car when it sold. So, he listed them on ebay separate from the car after I inquired about the springs.
I check ebay once a day just for M45s and parts just cuz you never know what's going to be posted.
I hope you are able to locate a set though...i had just about given up
nmgoodthing
Car: Brilliant Silver 2003 M45 / Pine Silver 2004 Lexus GX470 / Black 93 300zx TT
Caug, anyone that is as Tein resaler can order them for you.
saeedakobiakov
Car: 03 M45
i am not interested in tein, they just too soft.i was taking about ibech.
DRIPS
Teknic73 wrote:1. LaCapitalRue2. JBillion3. xxNite4. peter_rabbit5. teknic736. DRIPPS. (interested depending on quote)7.8.9.10.
All this about the springs...what about the struts? what are you guys pairing with these?
ANyone done this install? I have done suspension before but would love to have a write up on this cars susp.
xxNite
Car: 2004 Infiniti M45
'98 Toyota Supra Turbo
unfortunately due to availability, you are really only able to find and use factory struts with the lowering springs by TEIN or EIBACH. I have 54Kmiles on my car and put the TEIN S-Tech lowering springs on about 1000 miles ago. The feel is okay, but I don't drive the car like-I-stole-it, so it works for me.
M45 2004
DRIPS
how much you think we are all in for then Including struts, springs, shipping, bushings, gaskets, bolts...?
ALso, I thought it was bad to pair lowering springs with stock struts because of the compression or something being dampened a bit due to the shorter spring? Overall causing shorter life on the brand new strut?
DRIPS
CakeDaddy wrote:props to you on locating the eibachs. You wont be sorry!!! ____________________• Locomotion:Y34 ~ 4.5Liter V8 ~340HP~ 333lbs Torque• Construction: Blk'd Out Grill, Blk'd Out Side Marks • Coloration: Black Obsidian• Elevation:Eibachs • Rotation: f 20x8.5 245/35zr ~~ r 20x9.5 265/30zr• Rotation Specs: f 34mm offset ~~ r 40mm offset• Rotation Design: Foose Speedsters on G-Force T/A KDW 2 • Reflection: 5% Tint All Around• Vision: OEM 4300K HIDs w/ H3 Piaa Yellow Fogs • http://www.cardomain.com/ride/2690246
whats teh part number for the eibachs on our y34?
xxNite
for Eibachs:The part # is 6371.140
DRIPS
xxNite wrote:for Eibachs:The part # is 6371.140
I found the eibach springs on this site:
http://mynismo.com/products/?id=3104
Can someone confirm that these are indeed the springs that will fit my 03 y34? Based on the feedback of the teins, I would rather go with the eibachs. I have had a pro kit before and was happy with the ride.
paperfootball
DRIPS wrote:I found the eibach springs on this site:
I would be willing to bet dollars to doughnuts that they have the info wrong. Try calling tham and see if they indeed have that part#. It should be 03-04, then 05 up, not 04-06 as they have posted. I would call....
dtdm
Car: 2003 M45
I contacted mynismo a few weeks back. I received this email "Hmm, yeah we had some a little while ago, and someone else asked for the same thing, he ended up buying the Japanese spec Tein lowering springs instead."
So i don't think that helps out with anything.. do you have the part or not?! I wrote them back but have not heard back.
ClutchKick
Car: S14 Y34
Eddie over at MyNismo.com has his hands full... I actually built that web site years ago...
The part number is accuarte for the M45 Fuga 2006+ model. Not for the Y34 M45...
The coils are totally diffeent on the new M's from the Y34... Different diameter in the front / rear etc...
When I called Eibach ages ago they had no longer made the Y34 springs... I do not recall the part number for the Y34 springs but it was different from the Fuga...
TEIN and I think it was JIC or Parfume are the only company's that made springs for the Y34...
I can still get them all...
DRIPS
Clutch you rock! I want a lower and stiffer ride built for performance. WHich of the springs would you recommend and what is the cost of each?
DRIPS
DRIPS wrote:how much you think we are all in for then Including struts, springs, shipping, bushings, gaskets, bolts...?
So the best quotes I have so far are:
250 for Tien365 for front struts360 for rear struts105 for wheel bearings----------------1080 shipped to me
I cant believe the cost! Although, I guess that is what I expected since the car is rare...
Fred-Don
Hey Clutchkick, do you still have Teins or Espelir springs on stock or can you place an order for me and for how much??After all my research so far I think these two are the only options I have left for my 2003 M45...do you recommend either?
SoThrowedMex
Car: 2003 Infiniti M45 WV2 Silverstone Metallic Clearcoat on 235/30/ZR22
jbillion wrote:Count me in!!
I'll start the Group Buy list
1. LaCapitalRue2. JBillion3.4.5.6.7.8.9.10.
I know I am late and all but I would like the lowering springs for my Y34. Question, I have 22" wheels on it, can I still put these on? Will they rub tremendously? I want to lower my car so bad.
**I know this is an old thread but barely got my car 3 weeks ago. :sad:
Tony Two-Tone
22s will more than likely rub.
SoThrowedMex
Tony Two-Tone wrote:22s will more than likely rub.
Yea kinda figured that. I would probably have to do a fender roll or something. Thanks for the response Tony. :mike
Tony Two-Tone
NP bro.
I'll also go ahead and tell you to go with coilovers instead of springs. The prices are much more reasonable now-around $1000
SoThrowedMex
Tony Two-Tone wrote:NP bro.
Ouch, $1k is not reasonable to me lol. I thought they were hard to find for springs, im sure the coilovers are near if not impossible to find as well.
nuge
Car: Infiniti M45
I have a set of brand new Eibach Pro springs. See Ebay auction.
http://www.ebay.com/itm/121176427077?ss ... 1555.l2649
Item #: 121176427077
