gmac708 wrote:I don't want to get into the upgrade yet.
I can justify an upgraded turbo, but then do I have to do the fuel injectors, and the map the ECU, and then go to a top mount, and maybe... nope, not going to do it!
I think I should stay with a good reliable T28 and just get the car running at 9PSI. Let the kid get thru the winter on all season radials. He can save his pennies and save up for all the goodies. You gotta want something to appreciate it.
I sent an e-mail and talked to Karim at Total JDM. He said they normally do not warranty the turbo after the first 30 days. He said I should have checked the turbo for free play before the engine ran and reported it, if it were bad. I explained that it took 6 weeks to get the harness done and that I got the harness back on Friday and had the engine running on Sunday. He also said he did have a few turbos from engines but he was not sure about a T28, but said if he did have a T28 he will send it to me...FREE! He will call tomorrow.
All that being said, where would the best place to get a turbo be.
I will say this about my top mount T3-T4. Impressive, I ran my friend with his T25 at 14psi and it was no contest. You will lag a little more but it comes on so much stronger. Plus an external waste gate is just... OH so nice.
As for getting a cheap turbo, You could always try your luck at the junk yard, Get someones used turbo, Or run an ebay. A lot of people rag on ebay turbos, Mines held up for 2 years and still has ZERO shaft play.
If you want a new turbo, Check out some of nico's vendors. I know Phase2 sells them.
