Ok, So I'm new here...
not a total noob, but my father (who is a mechanic) and I have run out of ideas, and my local repair shop is stumped also.
THE CAR:1991 240sx ka24de manual trans. everything is stock
THE PROBLEM:The engine has been running extremely rough. At idle, it is enough to shake the entire car. At speed, it is less pronounced, but has a noticeable power deficiency. When coasting, it smooths out quite nicely, but as soon as throttle is applied it runs ragged and underpowered. To date, I have replaced the following - fuel injectors, plugs and wires on all cylinders, distributor cap and rotor. None of these had any effect. Each injector has been tested for resistance, and they all tested the same. Compression test came back 140 psi on each cylinder (i believe. it may have been 130, it's hard to remember. Whatever it was, I know it was consistent on all 4). Timing is good, and even though the upper guide for the chain did break off and was bouncing around before I got around to pulling it, it didn't seem to do any damage. Each plug is getting the fire signal, and the injectors are working, but I have nothing happening in the last cylinder against the firewall. I think I have covered all my bases so far, but if there is anything I have missed, please let me know and I'll see if I can find that out.
my next step from here is either going for the ECU, or maybe the coil pack, but I cannot afford to keep throwing money and hoping I'll hit the problem.
I have owned this car for 7 years, and although I had a few other cars before it, i consider this to be my *first* car. Got it for $1400 and have put 80k miles on it, but I don't want to give up on her yet. It was running great just before this, and then it just started one day after a fill up. It was so out of the blue, I figured it HAD to be bad gas...the rest, as they say, is history...
any and all suggestions are appreciated!
oh, and her name is Natalie, if that helps
