mechanicalmoron »
https://forums.nicoclub.com/mechanicalmoron-u183526.html
Sat Jul 30, 2011 1:56 pm
I thought these two things where related, but I'm not sure. I think it should be an easy diagnosis, if I'm describing it right, but I may not be.
Symptom A: in reverse, particularly when the differential is cold (I THINK, like any intermittent problem, it's hard to tell for sure) I get nasty groanings, and the vehicle shudders. Doesn't seem related to being in gear or not, although it may not be as bad if I'm accelerating backwards, like if I coast down my driveway it will happen. Will suddenly cut on, groan a few seconds, and stop. Again it's hard to tell, but it seems to happen more when I'm turning, so the wheels are turning different speeds. could be my imagination though.
Symptom B: When accelerating hard and cornering, specifically up a steep hill, and specifically cornering to the right (on the hill I'm thinking of where this usually happens, usually accelerating from 25-35 ish, and pushing the car about as hard as it will, its quite a hill) I get a HORRIBLE shuddering, violently, and rumbling from the back, I THINK from the right side, sounds near the same place as the groaning in reverse, but it's hard to tell. I mean, the kind of thing that makes passengers scream in fear, it feels like I'm taking howitzer fire. If I stop giving it gas, it stops pretty quickly.
Almost feels like that whole corner is repeatedly bouncing in the air, though I have fine traction the whole time. It's the sort of thing that bounces things around, rattles my change...
Changed my diff oil, was no damage to gears I could see or feel, no chunks/shards, although the oil was very old and sludgy, and had plenty of metal mush on the magnet. Gears felt nicely/evenly worn, and in okay shape, to me. Didn't make anything better at all.
