This is the most rediculous thing ive ever heard on this thread !!! Why get custom cams grinded if they make plenty of cams suitable for all types of driving styles and setups!!! You dont need a standalone too expsensive!!!??WOW !!!How many fast cars have u actually built ? Yeah you dont need a standalone if u dont plan on making any serious, reliable hp and how else would u be able to run different ignition timing maps fuel maps or run w/o the mafs with the stock ecu !!!! Not to mention if your running wild cams in your engine............Ari G wrote:Use the stock ECU ,Standalone is expensive and you don´t NEED it
For everyone looking for a cam,Get a custom grind no matter what
256 might work a little better wit hthat turbo. but with my gt2871r .64 my BC264 cams worked greatDBo wrote:who is running BC 264/264 cams? would you recommend them because im tryin to decide on which cams to buy.
head setup:3 angle valve jobJWT bronze valve guidesBC springs and retainersRAS
im currently using a s14 t28 but i want to upgrade to a s15 spec r t28. im goin to run about 17lbs on with turbo and i was thinkin about gettin 256/264 toda cam or the 264/264 bc cams.
ive read all 6 pages and their was very useful info. just need to see wat ppl think
should probably say which turbo/size moves which amount of air. newbs, like me, wouldn't know considering we had to ask about cams per turbo.DrifterProdigy85 wrote:Lets make a new updated list of how to select the right cams. Im gonna base it on the flow rate (lbs/min) of the turbos. So to eliminate alot of "what cams should i get questions", just follow this list and you should be perfectly fine.
30-40 lbs/min - 250 duration cams 40-55 lbs/min - 260 duration cams 55-75 lbs/min - 270 duration cams75+ lbs/min - 280 duration cams
quick question: I have hks 256/264 set and was thinking about buying this tuned ecu from a car that had 264/264, would this work alright on my car if all the other mods were the same(mafs, fuel pmp, injectors, etc...)?
Modified by VNG704 at 11:46 AM 3/20/2009
Okay so my next question is how would my engine perform (powerband-wise) with that ecu and my 256/264 camshafts? Note that all mods from original car and my car are the same (s15 turbo, fueling, mafs, etc... minus camshafts). I hope this is in the right thread being partial cam specific.idahotuner wrote:
That S*** is no joke. I am right there with you. Late reply I know.Just going through this thread to buy my cams... well, everything I need to build my motor.RCCC_DRiFteR wrote:That's dope, I almost have an anxiety attack just thinking about all the work and things I need to get though
Poncams or 256's only if your staying with a S15 turbo or smaller. IMO240sxHitman wrote:hey drifter, whats your take on the Tomei Poncams and are they good for low or top end?
