sa3reghatch »
https://forums.nicoclub.com/sa3reghatch-u43560.html
Fri Mar 21, 2008 5:36 pm
I just got finished with my build on my SR. got a dyno baseline at 13 PSI(didnt have the MBC turned to 20psi which is what I want). Anyways, my setup is built motor, HKS 264 step 1's, Full racetwin scroll manifold and twin scroll gt3071R,enthalpy rom tune,830cc injectors, greddy intake manifold, Z32 maf,etc. This is my dyno at 13lbs. If you cant read it cuz its too small it reads 300HP 278lb tq. For some reason it seems a little lower than I expected, i compared it to the dynograh they have on full race's website,and the full race graph seems to have it spool faster than what mine is spooling at. i know their are different parameters and setups, but I would think they should be more similar than they actually are. I'm assumming I need to run different cams. need to check all my vband fittings and make sure they are tight and I dont have a exhaust leak.
gonna fine tune it with a SAFC to lean it out and raise boost to 20lbs. I'm looking for 400+HP and 330+tq. Think that is reasonable?
