StryfeS13's Build Thread..No more KA-T...5.3L LSx
StryfeS13
Car: 1993 Nissan 240SX
My freeze plugs arrived. Came with some extras...idk why?
My turbo drain bung + cap came too.
I figured I'd do a write up about this, since all the other threads are old and the pictures no longer work, or something of that case.
This info is from a 240sxtechdvd's video on youtube, I'm just putting it in text form.
Materials needed:
Earl fitting: 967110ERL
Earl fitting: 992910ERL
Drill with 3/4" unibit, or whatever you want to use to make the hole (i didnt have a 3/4 inch so i used a 1/2 inch and a file..)
Grinder
Here are the fittings
Here is the location you will be drilling, if you want to keep your a/c. If you dont want to keep your A/C, drill where ever you want, but make sure it is as high as can be.
This is 8 1/2" to the center of the hole, 1" down.
Here's a better picture of the location, when you drill, it should be going through this baffle.
Next, get your drill, start off with a pilot hole, and eventually you will have this. Keep checking to see if the bung fits in, dont make it too big. Get your grinder/sandpaper and remove the paint so you have bare metal. You will have to grind the lip down a little bit, so you can fit your welder in there to get the top of the bung sealed. (as seen in pic)
Now you're pretty much done, you just have to weld it in.
The last picture is showing that you want the bolt to be straight, like that, so you can access oil pan screws easier.
StryfeS13
Sorry for the lack of an update, not like anyone cares :X
I've been trying to get my car smogged, so that's where all my money has gone.
I finally got it to pass so my KA will be done soon. Then I'll start on wheels/suspension, then after that I'll start to piece together my turbo set up.
Anyway, all I have left to buy to finish the KA are head studs, a gasket kit, a timing kit, and a clutch. :dblthumb:
S14Kouki10
Car: 1997 240sx
StryfeS13 wrote:Do you guys think it's necessary to invest in aftermarket valves, retainers, springs, or can I keep the stock ones and be fine? Or can I use aftermarket valves with stock retainers, springs, etc?
what route did you go on this?
StryfeS13
Stock valvetrain.
allenms240
Car: 1991 Nissan 240SX
I'm digging this build Stryfe. You see to really know your stuff, like the PVC and intake stuff.
What are you doing for fuel?
StryfeS13
For right now...I'll probably just leave the stock fuel set up.
But when I go turbo it'll all be changed accordingly. i.e. walbro, ecu, z32 maf, injectors, etc
I got a pair of sportmax 006's today for 100 bucks, mint condition. they look gay on my car though cause it's not low enough to make an 18" look good. But I don't really care...coilovers will come later, after i finish the motor.
I'd post pics of them on my car but it's a 4X4 truck and they look horrible.
StryfeS13
Here's how it looks. Really needs coilovers, sits way too high.
S13AL
Car: 1991 240sx hatch with blacktop s13 sr20det, HKS Hipermax III suspension, HKS Sport exhaust, Blitz downpipe, S15 Sylvia HLSD, 300zx/J30 5 lug and brakes, and mesh wheels
I will probably get $hit for this, but I honestly like the wheel fitment in the last pic.
Besides the undercarriage sitting high the way those wheels fill out the fenders looks nice.
StryfeS13
And here's where I left off today. Tomorrow, I will assemble the whole bottom end. :)
My bottom end is pretty solid.
-Rock main bearings
-ACL duraglide rod bearings
-Eagle H-beam forged rods
-Supertech 8.6:1 forged pistons
-ARP main studs
tm1218
Car: 240sx
at least do aftermarket valves alone. it would suck to skip those and end up needing them after. I cannot tell you how many times I come across people selling KAs and SRs with bent valves.
StryfeS13
Answer: ...the key is a half moon shape and you can just push it straight. Lol. And the other thing goes in your idler sprocket.
So I started assembling the block today...checked my clearances, they're all perfect, lubed up the bearings, installed the crank..But then I noticed something...
Is this even a KA24DE crank!? I have never seen the key slanted, like that. It spins smoothly and has no trouble whatsoever spinning...so I think it is the right crank, but that slant is confusing me.
And what is this thing?
EDIT: LOL Im an idiot.
motoman399
Car: 98' wrecked (RHD coming soon) 240
the key way is removable and is in the shape of a half moon. it will slant a little, just tap it flat with a hammer. and yes that looks like a kade crank. your good. the "thing" in the second picture is the piece that goes inside of the idler sprocket on the timing chain. i think there is a washer that is associated with it. cant remember where exactly.
StryfeS13
Yeah I found out what the second picture was, like right after posting it.
motoman399
^^ cool. well just make sure you clean that crank off. use some brake cleaner and get the oil residue off. looks gross lol. but the rest of the build is looking good man. congrats.
StryfeS13
Well, I just bought my timing kit. So now all I have left is a gasket set and a clutch. Then it's finally DONE.
I've been keeping a log of the cash I've spent..and I'm already at 1.6K.
nightsauce
Car: 1991 Nissan 240SX S13 hatch RIP
1992 Nissan 240S S13 hatch :D
1.6k including machine work? cuz that too bad
StryfeS13
Yes, including machine work.
1.6K in total -
Eagle Rods
Supertech Pistons
ARP Main Studs
ACL Duraglide Rod Bearings
Rock Main Bearings
Timing Kit
Block Bored .020" over
Block Honed
Block Resurfaced
Head Resurfaced
Ported/Polished Head
Intake Manifold Port Matched
EGR Blockoff Plate
Turbo Drain Bung welded to oil pan
Oil Pump Rebuild
Thermalnator intake gasket
Etc...there's more, just cant think of it.
motoman399
that doesnt sound like a bad price at all. good job man.
nightsauce
motoman399 wrote:that doesnt sound like a bad price at all. good job man.
yea he said it. I'm in hardcore savings mode right now, trying to build a ka-t just like you.
StryfeS13
How far along are you with your Ka-t?
Got bored today and sprayed the valve cover.
The oil cap has gold overspray..but that doesnt matter.
nightsauce
page3 woot woot...lol havent started on my KA-T yet. Just graduated college and started working this past week. Picking up a manifold next week because my friend has it for cheap, but I gotta find another motor to build while I still drive mine.
StryfeS13
Sorta big update! Got the bottom end all done up. Looks beastly :dblthumb:
The lifesaver, beats my old s*** needle torque wrench
Moly lube
Checking the ring gaps
The block before the internals were installed
Pistons Installed!
Shot of the ARP main studs, eagle rods..
Cylinder wall
Waiting to be finished
:werd:
StryfeS13
No love? haha
Just cleaned up the lower intake manifold, no ugly lines anywhere.
simplicity (ignore the harness stuffed in the runners, it's so I wont lose it)
My S13 ready for war haha
costa_rican13
Car: 1993 s13 coupe
looks good! i gotta a t3 for my ka. i need funds cause i gotta isht on this guy that supposedly gona have a SC on his rsx(base model ):)
StryfeS13
Thanks!
Haha, well why do you have to s*** on him? A SC RSX is pretty quick. K20/K24s are seriously no joke!
costa_rican13
Car: 1993 s13 coupe
Because its only the base model the 160 hp k20. And i can still beat him now even with my full bolt on ka. So he's gone sc, and im gona boost. Plus im gona have almost non lag as well. So im hoping i will burn him off the street.
hoosier240sx
Car: 1990 Nissan 240sx KA24DE
Nice build man, can't wait to see the finished project. Hopefully I'll be doing what your doing this winter!
nightsauce
hoosier240sx wrote:Nice build man, can't wait to see the finished project. Hopefully I'll be doing what your doing this winter!
im saying the same thing...gonna start a build thread in the next month or two.. :D
StryfeS13
Let me know when you guys start your builds!
My timing chain kit came today. So now all that is left is a gasket set, and a clutch. :dblthumb: :dblthumb: :dblthumb: :dblthumb: :dblthumb:
S13_RB25
Car: A 240 but no RB yet!
Im not going to lie but I'm a little jealous of your build thread lol. I got a build thread too but its just an OE build and then turbo. Either way my next build sure will be like this. Keep it up man, this thread rocks!!!
