StryfeS13's Build Thread..No more KA-T...5.3L LSx
costa_rican13
Car: 1993 s13 coupe
motoman399 wrote:what turbo's do you have^^
i have a t3 from a 300zx, and a t28(t3 flange) :) off an rb20
StryfeS13
Car: 1993 Nissan 240SX
I promise I'll post a video once I fix this timing issue.
It sucks that i have to take s*** back apart, but it's worth it. The engine is pretty damn fast and it's not even timed right, I can't wait till it's running normal!!!
costa_rican13
Car: 1993 s13 coupe
YES! video FTW!
StryfeS13
I fixed my stupid timing issue!!
And just for anyone that has any problems like that, I made a write up on how to fix it.
how-to-fix-an-incorrectly-installed-tim ... 08263.html
I also figured out my wiring issue. I accidentally grounded my alternator ground to the alternator itself, lol... :tisk:
Fixed that, drove around for a week with some rigged fuse since I couldnt find a 75A. But I found one on ebay and now everything is correct. I also installed orange lights in my gauge cluster.
Coming in the mail right now are my electric fans so I can fix my overheating problem (bad clutch fan) :bigthumb:
Only other problem left is my TPS, it's not adjusted correctly. Other than that, I fixed pretty much everything! :dblthumb:
S13AL
Car: 1991 240sx hatch with blacktop s13 sr20det, HKS Hipermax III suspension, HKS Sport exhaust, Blitz downpipe, S15 Sylvia HLSD, 300zx/J30 5 lug and brakes, and mesh wheels
Glad that you fixed most of your problems.. I hope you don't have anymore pop up!
StryfeS13
Today I was tracing leaks. Found a gas leak and a small oil leak.
The gas leak is coming from my fuel filter hose, it's corroded. So I'll fix that, easy. The oil leak is coming through the threads of my turbo drain, all that needs is some thread sealant. Easy fixes, for once. :P
StryfeS13
I haven't been updating this thread because I've been so busy working on stupid problems with the car.
First, the oil sending unit went out, for the 2nd time, and caused a huge leak. :bigfu: you, sending unit
So I bought this:
Second, my intake cam cracked while torquing the cam bolt back in.
Third, my clutch started chattering and is overall a peice of junk. People say it's a win/lose with XTD, guess I lost. Got a 50 dollar refund though, and bought an Exedy.
Fourth, my fuel line from the fuel filter to the hard line corroded causing a huge fuel leak, fixed that.
Fifth, my TPS wouldn't adjust to .45-.55V, but it passed the resistance test, so I figured it was good...changed it and now it's fine.. f^ck electrical.
Sixth, I need a new transmission mount.
Anyway, this is my dads CB750.
And the 240.
Does ANYONE know what size the differential bolt is? The long one that bolts into the frame, has a pointed tip, there are 2 of them. Because I'm missing one, and need to replace it.
I cant decide what to do next...feel good mods like shifter, steering wheel, suspension, brakes...or turbo...hmm :crazy:
costa_rican13
Car: 1993 s13 coupe
i say j30 diff next! grab them bolts too! you'll need them. sorry dont know what the bolt size is.
StryfeS13
I already have a Z32 diff!
changed my coolant today, since i got a new radiator from a friend of mine for free. It's just stock but in new condition. Got a 14" e-fan as well, and 5mm wheel spacers cause my front tires were rubbing on my springs.
nightsauce
Car: 1991 Nissan 240SX S13 hatch RIP
1992 Nissan 240S S13 hatch :D
go turbo :D
S13_RB25
Car: A 240 but no RB yet!
Hey just a quick question, did you use the dowel pin for the timing chain?? Right above the crank gear, like is it needed or not?? Cause mines doesn't stay there by itself, it hangs loose. So??
StryfeS13
The dowel pin for the timing chain..? Can you send me a picture? Not too sure what you mean.
I got my Exedy today. I'll install it whenever I have time.
kornmanz
Car: 89 240sx Hatch SR Powa'd
sweet build man. Cant wait to see the turbo on it and running videos.
StryfeS13
Thanks. Running videos will be soon! It's already pretty quick for N/A. If I launch it at 4K it'll hit 7K instantly and get all sideways. It's pretty fun.
I have been thinking about an sr T25 set up, since it's affordable. 370CC injectors, walbro, sr t25, sr intercooler piping, fmic (already have it), enthalpy tune, etc.
But for now, I think I should upgrade the parts of my car that have been left out, like suspension, etc.
motoman399
Car: 98' wrecked (RHD coming soon) 240
you dont need all those supporting mods for a t25. you could run stock injectors for probably about 8 psi on that lol. just an fmu and your dialed
StryfeS13
So today I finally had time to change my clutch. That XTD was a real P.O.S
Draining my most hated fluid on earth, gear oil.
Driveshaft out.
Shifter out.
transmission out.
Old crappy clutch. :mad:
New Exedy clutch :)
turbonxsx
yes i too f*** hate gear oil smells of all most foulest s*** on earth...
StryfeS13
Yeah, it's absolutely terrible.
Cleaned and painted my transmission, it was looking old as f*ck.
StryfeS13
Well since I have no money, and an urge to work on my car, I just decided to do some body work. I want to paint it, so I might as well prepare it. Yes I purposely chose the most obnoxious primer available.
Sanding down
After 80 grit, 120 grit, 210 grit, 230 wet sand
Nasty puke color primer
Test paint on bumper
StryfeS13
nightsauce
looks good doods
HeadAblaze
Car: Now: 1971 Datsun 510 w/ ka24e
Sold: Red 1990 240sx hatch
Nice work so far man, I just got done reading everything, ha. I have a leaky a$$ sohc ka motor and I hate it. I wanna do a swap sometime, bt may just get a shell, and do a VH45 cause after reading on that, it'd be crazy. But yeah, blah blah...good work.
StryfeS13
I <3 Rustoleum.
420sxWETDREAMS
Car: 1991 240sx Hatchback
StryfeS13 wrote:I <3 Rustoleum.
So you did it with a spray can? I would love to see it with the lights on it.
motoman399
not saying that the final product doesnt look good, but you really shouldnt use the rough of grit unless your sanding filler. to sand a panel that is just paint, you should use 320 and then 400 before paint. and if you have lots of orange peel or runs, then you can use 220. and for bondo obviously 80 to get it to shape, then 120 before primer, then sand primer with 220 then 320 then 400. but its looking good. keep it up.
StryfeS13
Eh. That pic was before body work and stuff. There's a bunch of pictures I didn't upload cause I'm too lazy. I fixed all the dents and stuff with bondo/spot putty, then sanded the car down with 320/400, primered it, wetsanded it, then layed on the paint.
and nah, it's rolled on.
FlipCoupe
nice paint, love when rustoleum paint jobs turn out good...when my coupe is running ill probably end up doing one :).
how many coats is that?
StryfeS13
5 coats. no wetsand/buff yet. letting paint harden
StryfeS13
It's not floored in first obviously, I kinda romp on it in 2nd.
Can't wait to boost it!
[youtube]http://www.youtube.com/watch?v=TMN8HMEakX0[/youtube]
nightsauce
StryfeS13 wrote:It's not floored in first obviously, I kinda romp on it in 2nd.
Get some gas. Lol. Looks good tho.
