Update, sorta.
-Pistons still haven't been shipped...no clue when FRSport is going to ship them.
-Bought a used oil pan off ebay, will be welding my turbo drain bung next weekish. but gotta cap it off for now...will be n/a for a while.
-Removed PCV. Tapped intake manifold PCV holes, then blocked them off. Gonna run a catch can...VC breather connected to PCV hose with a T, then from the T to the catch can, and then from the catch can to pre-turbo intake.
-Cant get anything for the car this paycheck, have to deal with smog sh1t...
And a question. When you remove your secondary butterfly valves, you obviously have to block off the hole where the swirl valve was, but do you have to block off the holes between each of the runners, where the shaft was? Or no?
Also, do you have to block off this middle hole right here? (between runners 2 and 3)
Answer: YES you have to block off holes in between each of the runners. And YES you have to block off the middle hole!!!
EDIT: Plugged it anyway...
if anyone is a computer nerd...a PCI bolt fits right in (the bolt that holds a card in its place)
And here's some more pics just outta boredom.
(rustoleum paint..lol)
